40mstew
How do you make a drop ceiling for only 1 room
I have a basement with a safe room. The ceiling is 10' high in the basement. I only want to drop the ceiling in the safe room that is in the basement down to 8' and keep the basement ceiling at 10'. Seems every time I try to do this it messes with the foundation and raises it. Not finding any videos on this. Or is it just as simple to turn a soffit into a ceiling???
There has to be a simple step by step solution to this.
Using X9.
Thanks
I typically just put a ceiling a plane (zero pitch) in a room that I need a different height.. esp when there is a room above.  Just did one for an example below...
A few ways to do this but one of the best...
Add the necessary layers to your ceiling FINISH definition.  From the bottom up:
-Ceiling finish layer
-Framing layer
-Insulation / air gap layer
Here’s a video I made a little while back.  It was made to address a different issue but probably worth a watch anyway...
Greatly appreciate all your input! All worked well in different ways.
Thanks all of you!
14 hours ago, justmejerry said:
I would just use a shelf ceiling.
Interesting,  I had not thought of this......  it might make sense to use this method if you wanted the ceiling TO SIT ON THE WALL and not hang off the wall.......  I think.......  suppose you selected the exterior wall and defined it as going through ceiling,  would the ceiling  now hang off the exterior wall?
I guess I didn't know what I was talking about,  my ceiling does hang off the wall.  So my question is,  why is Jerry's ceiling sitting on wall and not hanging from wall?
5a5379b9c78f3_ScreenShot2018-01-08at6_01_15AM.thumb.png.57c5c8d9f6eeff4674a1d2dd66fcd02f.png
The shelf ceiling has its uses, but in a situation like this, it is very difficult to control.  It will automatically hang on 2 or 3 of the surrounding walls but will always frame over at least one wall.  I have yet to figure out the program's logic as to which wall(s) it chooses to cut short.
Anyway, you can get the walls not to cut short at all by utilizing an extra single layer wall with a very small (maybe .01" thick) Insulation/Air Gap layer.  That way the filler wall gets cut short instead of the main wall.  This works pretty well much of the time but definitely not all of the time.  Depending on your design, I think you'll still find that using the shelf ceiling tool for this type of situation may prove to be more hassle than its worth...
I thought the Shelf Ceiling ( Plant/Display Shelf) was typically only used for situations like a Closet Area in an otherwise Vaulted Room , say a Master Bedroom or Foyer, not sure if that accounts for the one side never framing like the rest?
Perhaps Jerry's Basement wall is a Furred Wall ? not sure if that makes a difference? as I didn't do a test drawing .....
3 minutes ago, Kbird1 said:
I thought the Shelf Ceiling ( Plan/Display Shelf) was typically only used for situations like a Closet Area in an otherwise Vaulted Room , say a Master Bedroom or Foyer, not sure if that accounts for the one side never framing like the rest?
I think your estimation of this situation is correct.  The shelf ceiling wasn't made to drop a ceiling structure inside a room envelope so much as it was made to drop a room envelope within another room envelope.
    27494
    theCADStudio
    theCADStudio
  • Similar Content
    • By SNestor
      OK...I've been messing around with the "Tray Ceiling" tool in X12.  Cannot for the life of me figure out how to create a "nested" tray ceiling.  In the help file it shows to unique icons...one for a "tray"...and one for a "nested tray".  I cannot find where this "nested" tray menu or icon exists.
      Is the nested ceiling shown below in Example B possible with the Nested Tray Ceiling tool?  Thanks!
    • By David-R
      I am trying to draw suspended ceilings for my office area and having a problem with the suspended ceiling not starting a new grid alignment between some offices in 3D view.  I want each office to have it own ceiling grid layout so I don't end up with small edges and misaligned ceiling tile and lights.  It works between some rooms but not others.  Here is what I do...I use "Draw Line" to layout my ceiling pattern, then I place my recessed lights where I want them, I go into "Room Specifications" -> "Materials" -> "Ceiling Finish" and select "Square Ceiling Tile."  After all that, I go to camera view...I then use "Adjust Material Definition" and select the ceiling.  On the "Pattern" tab and the "Texture" tabs I change the "Horizontal Offset" and "Vertical Offset" to match the lights.  In some cases this works fine and other times the Horizontal Offset and the Vertical Offset don't stop and the interior walls and they adjust the ceiling on the other side of the wall (in the next office.)  I can't figure out what I am doing differently that causes it to work properly some times and not others.  Any help will be greatly appreciated. Thank you, David-R
    • By blueriver
      I have a persistent problem with gaps in my porch ceilings in between the finished surface and the underside of the roof structure.  I know it has to be a setting i have wrong but i cannot figure it out! Current project is a barndominium with a gable porch.
      Thanks in advance
    • By Designer100
      I do not even have client yet. But contractor roughly gave me info. I need the 2nd floor living area to be under roof of this metail bldg. with 16 ft eave ht. I was making 1st floor ceiling under living area at garage 2 area and then garage area 1 open to steel rafters. When I make a bldg. section it is not putting cabinets and room where it is surpose to be. I want it to be like attached elevation. when I make the garage area to ceiling 11' then it changes the whole right side of bldg. eave ht.
      I would apprciate any help.
      Thanks,
      Newell
      Starr.Cole Seabrook Metal Bldg.plan
    • By SamanthaSkidmore
      I'm not sure when this happened or how it happened but my ceiling isn't meeting the wall in the basement.  The separation is from the garage.  I created a brand new plan to make sure my heights all matched up correctly and they do.  Can you tell by looking at my screenshots what might be happening or what I need to do to fix it?  Photo on the left is the wall/ceiling in the basement.  The photo on the right is from the garage.
      Thanks so much!
