I recently upgraded to X-9. I'm experiencing (Trump-worthy) HUUUUUUGE lag times when switching from one view window to another. When attempting to switch views by using the drop-down menu under "window" in the main taskbar, in addition to the HUUUUUGE lag time, my aggravation level is further tested by taking me to a view I did not select!!
Anyone else having the same problem?
ED
Cadd Creations
Yes, that takes me to the correct view that I selected but still the huge lag time. I'm talking several minutes.
As a side note, I often prefer to use the taskbar "window" menu when switching views particularly when I have several windows open because the tags shorten to the point where they are unidentifiable.
Ed
Cadd Creations
X9 changes the way Graphics work , so I suggest checking the system requirements for X9 and Filling in your Signature ( see mine for how) with your system specs and hopefully someone with a similar system can help out.
I am assuming this issue is with ALL plans , not a particular plan.....
I just don't get that kind of slowness so it has to be a system problem , for me, one time a mouse driver caused some slowness, and the other time was a macro problem and the last was using, generated sun and sun follows camera together. all fixed except the last one which should never be done together anyway.
Nor I.
I have this whenever I have some crazy large PDF in one of my drawings or layouts.
I’ve since corrected this by converting the PDF to a much smaller size PNG.
No reason to have PDF actually.
Now views switch instantly regardless of how many windows I have open.
I have the same prop with pdfs and pngs. The pdf files have a tendency to partially disappear when zooming in on them. The problem I'm currently experiencing started after I upgraded to X-9. Its unrelated to the picture file issue, I believe. Im probably gonna call support today.
p.s. My PC system is well above the min. requirements as well as the recomended ones.
    27461
    WaunakeeDesigner
    WaunakeeDesigner
  • Similar Content
    • By TECsta
      Hi
      Recently got the lastest version of room planner. As i always welcome advancements i was keen, however its performance is lagging hard, Takes too many taps to paint and too many attempts to place furniture..
      Please advice..
      And PLEASE get performance back to the way it was on previous versions, if this is a known issue........
      Thx
