Moving Chief to D Drive
Rachael_Venue
you can use windows ability to move Library Locations to easily do that  , here is my post from a few days ago for someone else
here is perhaps a better guide than mine  :)  you can also move your
Pictures, Music, etc Folders the same way...
Move Documents ( including Chief Data folder)
https://www.tenforums.com/tutorials/74952-documents-folder-move-location-windows-10-a.html
Move Pictures
https://www.tenforums.com/tutorials/74942-move-location-pictures-folder-windows-10-a.html
Move music
https://www.tenforums.com/tutorials/74966-move-location-music-folder-windows-10-a.html
Move Downloads
https://www.tenforums.com/tutorials/74949-move-location-downloads-folder-windows-10-a.html
Move Videos
https://www.tenforums.com/tutorials/74955-move-location-videos-folder-windows-10-a.html
19 minutes ago, Rachael_Venue said:
Hi All - I don't have enough space on my C drive to continue using Chief Architect there.  Does anyone know how I can move it to a different drive (D Drive)?
Rachael,
I would just move the Chief Data Folder and your Chief Projects to the D Drive.  In Chief Preferences you can set the Paths by browsing to the new location(s)
I've been using this for several years.
I started with Chief 9.5 and put Chief on another drive
did same with Chief 10
however, every time I called tech support they claimed that was my issue
so I put Chief on C: and have been doing so ever since
check with CA's tech support first - maybe its not an issue now ???
Lew
You will be back to the forum before long with a list of things not working right.  Stay with what works.  The analogy might be a mechanic that has customized some part of the engine to his car.  Most people just want to drive the car with the least amount of headaches.
Agreed that C drive is the recommended location according to many posts over the years.
...For some reason sooner or later, you may or may not experience a random wonky issue, and invariably it has to do with the drive placement.
