What is wrong with this wall
dshall
I run into this all the time.  Started with X9 I think.  Not sure what the problem is.  In my case It will show siding but when I change the material
in the dbx it doesn't change the pllan wall.  So I bring out the spray can.  I think I posted on this in the past.
Scott,
Try this with the original wall.
In a 3D view, click on the block wall and notice how it's boundary hilites.
Drag the top of the block wall down to reveal the siding wall.
You can't actually select the top part of the wall - all you get is the junction between the top and siding/block walls.
Very strange indeed.
It's like you have 3 wall definitions in that pony wall.
Are you using the next beta version?
1 hour ago, glennw said:
Scott,
What beta version?, I don't think any beta's are out at this stage.
1 hour ago, AndyGump said:
Go to Structure tab and click on the "Default Wall Top Height" button and the exterior layer will come back.
I don't know why it set like that but it is.
Andy.
Good call Andy,  thanks.  BTW,  I did not drag that wall down.......
