wncbw7 Posted July 3, 2017 Share Posted July 3, 2017 See attached image. In center of image there are lines at the ceiling and floor line. how can I make those go away. I have tried to find the layer they are on with no success. I have turned off the layer ROOMS and that eliminated some of these extra lines. Link to comment Share on other sites More sharing options...
dshall Posted July 3, 2017 Share Posted July 3, 2017 If you are talking about the horizontal lines I have highlighted, I recently ran into this. Here is my fix........ in a 3d view, select wall, open it.... say a few curse words........ and then close it. FIXED, at least that is what I did for 4 different locations on the same elevation view. I cannot explain it, I did not change wall type, I did not align the walls..... I did nothing except open the walls and the close. Please let me know if this worked for you. 1 Link to comment Share on other sites More sharing options...
wncbw7 Posted July 3, 2017 Author Share Posted July 3, 2017 Must not have said the right curse words, that didn't work. However i selected the top wall and pulled its bottom up to the upper line and that made both lines disapear. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 3, 2017 Share Posted July 3, 2017 Just remember if you pull wall down all the framing and drywall go with it, and your sections will be screwed up. I will never drag a wall unless it's a very simple pull. Sometimes after you print to PDF some lines will go away. Link to comment Share on other sites More sharing options...
ShaneK Posted July 3, 2017 Share Posted July 3, 2017 Post the plan. Link to comment Share on other sites More sharing options...
johnny Posted July 3, 2017 Share Posted July 3, 2017 I feel the OP's pain. Unclean connections are the bane of my Chief experience. Chief doesn't even make a good way for us to cheat the issue like Sketchup and other apps do - hiding any line/edge you want. Michael is a connection god in Chief, but it really involves some deep knowledge on how chief behaves. Link to comment Share on other sites More sharing options...
glennw Posted July 4, 2017 Share Posted July 4, 2017 That looks like it may be a wall definition problem - post the plan to get the answer. There is usually no need to hide/delete any line - but can be done easily in layout. Link to comment Share on other sites More sharing options...
wncbw7 Posted July 4, 2017 Author Share Posted July 4, 2017 Drawzilla, Thanks for pointing that out. Sorry I can't post the plan, owners request for confidentiality. Thanks for your coments. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted July 4, 2017 Share Posted July 4, 2017 Change in wall type ,Walls not lined up maybe, just guessing. Have a great 4th,Ken Link to comment Share on other sites More sharing options...
