ACADuser Posted May 25, 2017 Share Posted May 25, 2017 In a plan I changed a wall layer to Invisible in the DBX. Drew 2 new walls Then I used the Hide Layer tool to turn off TEXT layer. When I hit UNDO the last wall is removed Hit it again and the other wall is removed. Again the wall layer change is reversed & the TEXT layer is turned back on. Aside for the fact the the UNDO has no feedback information (what the hell is it undoing?) Have any of you experienced this erratic behavior? Link to comment Share on other sites More sharing options...
ACADuser Posted May 25, 2017 Author Share Posted May 25, 2017 Just tried similar in another plan & the Text layer was never turned back on. Is the turning off of a layer not considered an "ACTION" by the UNDO command? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 25, 2017 Share Posted May 25, 2017 I have been having lots of undocumentable issues, so if there is something that is easily reproducible please make sure tech is aware because they are working on the issues as they are identified. I have also recently resuggested the idea of having undos documented for analysis by tech an use everyday by us as in GIMP. Link to comment Share on other sites More sharing options...
ACADuser Posted May 25, 2017 Author Share Posted May 25, 2017 OK sent to Support. Thanks Link to comment Share on other sites More sharing options...
glennw Posted May 25, 2017 Share Posted May 25, 2017 Alan, Do you have the ALDO open when you are performing these actions? And is so, are you using it to perform any of these actions? Link to comment Share on other sites More sharing options...
ACADuser Posted May 29, 2017 Author Share Posted May 29, 2017 No Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 30, 2017 Share Posted May 30, 2017 I use such things a learning event, I simply avoid doing things that get negative results when I identify such things. Just because something is not programmed the way you expect does not mean it is "wrong" but rather you have merely uncovered a wrong way to use the software. There may be a bug to fix there but in the mean time I would refrain from making the same mistake over and over in an attempt to make myself right and make the software wrong as an exercise. That is all I see there. DJP 1 Link to comment Share on other sites More sharing options...
ACADuser Posted May 30, 2017 Author Share Posted May 30, 2017 Tech support said there is an unexpected behavior & will look into it. David, Sorry if I criticize Chief too much. After using Autocad for too many years I have come to expect a lot from a program aimed at professional users. The homeowner and occasional user will tolerate short comings in the software but it makes me crazy. I'll try to be quiet for awhile. 1 Link to comment Share on other sites More sharing options...
dshall Posted May 30, 2017 Share Posted May 30, 2017 14 minutes ago, ACADuser said: ..... I'll try to be quiet for awhile. No, do not be quiet, your voice helps all of us including CA, try not to be quiet, I think CA appreciates the criticism/help. 3 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 30, 2017 Share Posted May 30, 2017 Your helping everyone when you speak Link to comment Share on other sites More sharing options...
