Jason_M
Chief not working after Windows update 5/15/2017
Good morning,
I allowed windows 10 64 bit to do an update last night, and this morning Chief wont start up.  I tried to use the repair tool on the downloads page, and files were transferred, but still no action. I try to run as administrator, nothing.  It was working fine Friday.  Anyone else?  Any tips?
Win 10 Pro
version 1703
OS build 15063.296
Processor i7 2600K 3.7GHz
16.0 GB Ram
64 Bit
if you have an emergency then roll back the windows update
otherwise, contact CA's tech support they are open now
Lew
Good call Lew,
problem solved.  When Windows updated my PC, it rolled my graphics drivers to a WHQL version, which stopped chief from working.  Chief Support had me DL the latest from Nvidia (the driver that prevented chief from running was only 20 days old) and it worked without a hitch.
thanks,
Jason
I believe there is now a setting in the Windows Update section that allows you to tell Windows Update not to automatically update the drives. May be worth checking out as this may happen again.
I updated windows without any problems.
It all depends on whether the drivers you have match with the ones that Windows has in it's log. If it matches then nothing will change, if it does not match then Windows will change it to it's latest known version. There can be a lag between a manufacturers new driver being released and it getting approved and into Windows, especially if you are using a Beta driver.
Mine had a different issue that took at most 2 minutes to fix after nearly 4 hours installing tha Windows Creators Update.
Due to WannaCry ransomware had to run update assistant to get latest patches. It upgraded Windows 10 to 10.0.15063. No problem there.
ChiefArchitect would not open complaining about two DLLs: vcomp140.dll and msvcp140.dll claiming c:\windows\system32\vcomp140.dll image is invalid or corrupt.
This issue was related to update assistant upgraded these 64 bit DLLs with 32 bit versions.
To solve place 64bit versions into your
C:\Program Files\Chief Architect\Chief Architect Premier X* (64 bit)\ folder.
BT
Mine is working perfectly on my Desktop which includes the "Creative Update" and on my laptop which I have as a "Windows Insider" the absolute latest Windows 10 beta version. Sorry you are having a difficulty.
    27499
    Bren0625
    Bren0625
