GeneDavis Posted January 25, 2017 Share Posted January 25, 2017 If I define the wall as post-to-beam, edit it to have a middle rail and a shoe rail like we build them, how can I stick a door in one of the openings? Link to comment Share on other sites More sharing options...
javatom Posted January 25, 2017 Share Posted January 25, 2017 You can not use a rail wall to do this. Create a wall with definitions of screen material. You can use a pony wall to have the bottom part a different wall type. A door will then show up as a hinged door. You may have to create a door to your liking with screen material. It is a lot of busy work to get it to work. You could also just notate the elevations as having a screened porch and porch door. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 25, 2017 Author Share Posted January 25, 2017 Thanks. In that case I will go to the suggestion section. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 25, 2017 Share Posted January 25, 2017 Gene, This can be done. After creating your railing wall and setting as Post to Beam: Insert a Door - it will be a Doorway Select the Doorway, open the dbx, change the type to "Hinged" Edit the Height to what you want. It's been this way for a long time but I think it may be working a little better in X9 Link to comment Share on other sites More sharing options...
Evolution Posted January 25, 2017 Share Posted January 25, 2017 I do it the way Joe says, and also with walls both ways works fine for me and, I use a type F03 Hinged door, set the size, thickness and since it is a 2 panel glass door, I just go to the DBX, material, glass and make it screen. Link to comment Share on other sites More sharing options...
javatom Posted January 25, 2017 Share Posted January 25, 2017 I think he wants screen material to show up. Simplest way might be to do what Joe suggests and add screen material as a molding polyline. Link to comment Share on other sites More sharing options...
Evolution Posted January 25, 2017 Share Posted January 25, 2017 I don't have any problem with screen showing up. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted January 25, 2017 Share Posted January 25, 2017 You could also create a full height custom panel with the bottom, mid, and/or top rails as you want them, screen infill, and add the door per above. Only glitch is the space above the door if the door is not the full height of the screen panel. You would have to fudge that in with p-solids or moldings. Link to comment Share on other sites More sharing options...
javatom Posted January 25, 2017 Share Posted January 25, 2017 I could be wrong but I think he wants the walls screened as well. Something like this. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 25, 2017 Share Posted January 25, 2017 7 minutes ago, javatom said: I think he wants screen material to show up. Simplest way might be to do what Joe suggests and add screen material as a molding polyline. In X9 you can combine Panels and Rails. Just make a simple Panel with Screen Material. Link to comment Share on other sites More sharing options...
javatom Posted January 25, 2017 Share Posted January 25, 2017 That is a great new feature and would be the best method. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 25, 2017 Author Share Posted January 25, 2017 The rut I am in for screened porches is a simple post and beam frame, 3.5" thickness, square posts, tenoned into the 3.5" x 12" beam, top of beam up at 8/0 height above deck. We go full post where screened porch wall meets adjoining building wall, and butt the post tight to the sheathing layer. Wall runs are sized so we get between-post bays between 2/6 and 2/9 size in width. A door or doors go into full bays and height wise, run from floor to bottom of beam. I've played with a test model just now and can get pretty much what we want (X8), except I am unable to control the depth of the beam at the top. Does X9 give this? We don't care about seeing screening in 3D or 2D elevations. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 25, 2017 Share Posted January 25, 2017 Gene, You can set the width & depth of the Beam in the Railing dbx (the Beam is one of the "Rails"). This has been available at least since X7, maybe before that. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted January 25, 2017 Author Share Posted January 25, 2017 Thanks, Joe! Took a little exploring, but there it was. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 25, 2017 Share Posted January 25, 2017 After all that and I still didn't even get a rep point. 5 Link to comment Share on other sites More sharing options...
mwclassen Posted January 28, 2017 Share Posted January 28, 2017 On 1/25/2017 at 1:26 PM, Joe_Carrick said: This can be done. After creating your railing wall and setting as Post to Beam: Insert a Door - it will be a Doorway Select the Doorway, open the dbx, change the type to "Hinged" Edit the Height to what you want. It's been this way for a long time but I think it may be working a little better in X9 Wow! I spent an hour on my last job trying to figure out how to do that, and gave up by drawing cad lines. Thanks! Link to comment Share on other sites More sharing options...
ChiefGrego Posted January 29, 2017 Share Posted January 29, 2017 Where does it specify the size of the beam? because shouldn' the door still have a header as the screen door would be a standard height? Link to comment Share on other sites More sharing options...
glennw Posted January 29, 2017 Share Posted January 29, 2017 Railing Specification dbx...Rails panel...Rail Profiles...scroll down to Beam: Default Rail...choose a profile if you want other than a rectangle and change the size in the Selected Profile Specification beneath. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29, 2017 Author Share Posted January 29, 2017 Here is a screened porch with a hinged door in one wall. I moved the wall-side edge of the door to where it would be if the post adjacent it was a 4x4 (3.5" square) and the post tight against the wall sheathing layer. I get the look I want on the latch side of the door, but Chief shows a line on the hinge side where the half-post is. Door by me, from my library. Link to comment Share on other sites More sharing options...
