Cabinet and exteior elevation issues
Designer100
There are only a few possibilities with the cabinets:
- they should all be set to the same height.
- they should all be set to the same elevation reference.
- the should all be set to the same floor to bottom.
- they should all be in the same room (or the rooms need to have the same floor heights and thickness).
If all of this is true, then I have no idea what the problem could be.
