JECORMIER Posted December 12, 2016 Share Posted December 12, 2016 Hey All- Just had a quick question about this funny thing happening to my terrain area under my screened deck. It's not filling in like the rest of the area and I can't figure out what's making it happen. I believe it has to do with a setting in my floor above within the screened deck but I don't see where I can manipulate it to fill in. Hmmm. Got me stumped so let me know if you have any suggestions. Thanks a bunch in advance! JC P.S. See attached plan file. JOHN TERRAIN.zip Link to comment Share on other sites More sharing options...
Evolution Posted December 12, 2016 Share Posted December 12, 2016 Sorry, but the zipped file doesn't appear to include the plan.plan file? Or at least when I try to open it there is not a plan file available. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted December 12, 2016 Share Posted December 12, 2016 Open the terrain specification and uncheck "Hide Terrain Intersected by Building." Link to comment Share on other sites More sharing options...
HumbleChief Posted December 12, 2016 Share Posted December 12, 2016 Open the terrain dbx and uncheck 'Hide Terrain Intersected By Building' - oh wait what Richard said Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 12, 2016 Share Posted December 12, 2016 try making the screened walls no room defination Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 12, 2016 Share Posted December 12, 2016 try making the screened walls no room definition or a least one wall Link to comment Share on other sites More sharing options...
HumbleChief Posted December 12, 2016 Share Posted December 12, 2016 26 minutes ago, Evolution said: Sorry, but the zipped file doesn't appear to include the plan.plan file? Or at least when I try to open it there is not a plan file available. Bob, The plan file is within that long list of files in the zip file - at least it was when I looked. Not easy to find though. Link to comment Share on other sites More sharing options...
JECORMIER Posted December 12, 2016 Author Share Posted December 12, 2016 Thank you- Ok, well. the idea of unchecking the 'Hide Terrain Intersected By Building' certainly filled the missing piece in under the deck but......Now there is a full lawn growing in the basement. What now brown cow? J Link to comment Share on other sites More sharing options...
JECORMIER Posted December 12, 2016 Author Share Posted December 12, 2016 I also tried Drawzilla's option to have one of the screened deck walls with no definition and it worked like a charm! Thanks everyone! JC Link to comment Share on other sites More sharing options...
Richard_Morrison Posted December 12, 2016 Share Posted December 12, 2016 31 minutes ago, JECORMIER said: Thank you- Ok, well. the idea of unchecking the 'Hide Terrain Intersected By Building' certainly filled the missing piece in under the deck but......Now there is a full lawn growing in the basement. What now brown cow? J You draw a closed polyline where you want the terrrain cut, and change the polyline to a terrain feature hole. The problem with making a wall "No Room Definition" is that, well, you lose the room definition, and the associated information, like room name, square footage, etc. Link to comment Share on other sites More sharing options...
JECORMIER Posted December 12, 2016 Author Share Posted December 12, 2016 Man do I have a lot to learn! Thanks Richard. Great fix! JC Link to comment Share on other sites More sharing options...
dshall Posted December 13, 2016 Share Posted December 13, 2016 14 hours ago, Richard_Morrison said: You draw a closed polyline where you want the terrrain cut, and change the polyline to a terrain feature hole. The problem with making a wall "No Room Definition" is that, well, you lose the room definition, and the associated information, like room name, square footage, etc. That is the down and dirty solution... it works. I model my terrain to fit the building,,,,,,, a little bit more work, but when you get the methods down, easy peasy. Note in the attached pics, I have modeled the terrain as it will be built. Note the dirt you see WITHIN the building perimeter. Not super important, but I like to model the terrain as it will be build in lieu of taking the shortcuts...... both methods work, pick your poison. Link to comment Share on other sites More sharing options...
Dermot Posted December 13, 2016 Share Posted December 13, 2016 The program will try and cut out the terrain for the building automatically but it can't handle all situations perfectly. For instance, when the terrain intersects the building on multiple floors (the terrain just looks at the current floor). The best way to solve this is to turn off the automatic tool for cutting out the terrain and create your own custom hole in the terrain. The easiest way to do this is to first select the exterior room, make a room polyline, and then convert it into a terrain hole. You can then edit this terrain hole to include or exclude rooms as needed. If you have rooms on other floors, you can turn on the reference display to adjust your terrain hole where needed. There is no reason to ever have terrain in your basement or open holes unless that's what you want. Link to comment Share on other sites More sharing options...
johnny Posted December 13, 2016 Share Posted December 13, 2016 If the OP's issue is a "screened deck" then using the "deck railing" tool for the perimeter would be the most practical, and then the terrain won't cut under the "room". Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 13, 2016 Share Posted December 13, 2016 18 hours ago, Richard_Morrison said: You draw a closed polyline where you want the terrrain cut, and change the polyline to a terrain feature hole. The problem with making a wall "No Room Definition" is that, well, you lose the room definition, and the associated information, like room name, square footage, etc. It's under a deck , who cares. doesn't matter in this case. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted December 13, 2016 Share Posted December 13, 2016 1 hour ago, DRAWZILLA said: It's under a deck , who cares. doesn't matter in this case. Because you'll get the same terrain behavior if it's an actual room with windows, like a breakfast room, which may come up in the future. Why would you teach someone to use a half-baked approach when doing it correctly is just as easy, and gives you more flexibility and works in every situation? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 13, 2016 Share Posted December 13, 2016 Richard I don't understand what this comment refers to, some future condition? It's about underneath a deck ,where the OP wants the terrain to show, that's all. Link to comment Share on other sites More sharing options...
