Clemsongrad Posted October 7, 2016 Share Posted October 7, 2016 I'm getting close to finishing the model. What techniques or tools do I need to use to make the terrain look like real grass and not tiled? Also how do I blend it so that it harmonizes with the background images. I've searched the training videos but have not found any that address this. If there is, I'd like to know the name. Thank you! Larry I'm on a new/used PC and still have to get the specs off it. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 7, 2016 Share Posted October 7, 2016 All grass will be tiled, just look in the Library under Materials>Landscaping>Grass & Ground Covers and choose the one you like or search for a seamless texture online and import it, or make your own. The simplest solution for blending the transition is to make the terrain perimeter a little larger and throw in some trees,shrubs,gardens etc around the perimeter where the edge is visible and or the shape of the edge can be adjusted. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 7, 2016 Share Posted October 7, 2016 The best look.ng Ray Traced grass I have ever seen was done by Jentu Montego (Jentu Designs) where he made is own custom grass texture material. It is a bit of trial and error work but in his case it was worth the time spent. He has, in the past shared this custom texture here, last year, I think. DJP Link to comment Share on other sites More sharing options...
Mark3D Posted October 7, 2016 Share Posted October 7, 2016 For grass in the past I have taken a photo of a oval or other big area of grassed land and photo shop it in to the area but you should be able to place it in Chiefs texture slot and play with the texture sizing and see if it works , there are also image on the net that can be used I have not tried this in chief so are not 100 % sure it will work but worth a try Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 7, 2016 Share Posted October 7, 2016 A bump map for the grass makes all the difference Link to comment Share on other sites More sharing options...
Clemsongrad Posted October 8, 2016 Author Share Posted October 8, 2016 Thanks, Perry! I was trying to learn how to use a bump map earlier and watched the water tutorial. Haven't mastered it yet. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 8, 2016 Share Posted October 8, 2016 After all these years, I'm trying to figure it out myself, but it does make a great difference if you want it. You can have bumb maps for just about everything in the plan. Link to comment Share on other sites More sharing options...
dshall Posted October 8, 2016 Share Posted October 8, 2016 After all these years, I'm trying to figure it out myself, but it does make a great difference if you want it. You can have bumb maps for just about everything in the plan. Perry, would you mind posting a small plan with the grass and bump map you are using? Thanks Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 8, 2016 Share Posted October 8, 2016 I have seen others, that look very good, but at this time I can't. I will send you a note. Link to comment Share on other sites More sharing options...
dshall Posted October 8, 2016 Share Posted October 8, 2016 I have seen others, that look very good, but at this time I can't. I will send you a note. Maybe when I spend some more time exploring bump maps, we can get together and share ideas. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 8, 2016 Share Posted October 8, 2016 YES STILL LEARNING MYSELF Link to comment Share on other sites More sharing options...
Chopsaw Posted October 8, 2016 Share Posted October 8, 2016 Time for a Workshop?? Link to comment Share on other sites More sharing options...
Northriver Posted October 8, 2016 Share Posted October 8, 2016 Watch some of the render videos at Chief (The 2015 seminar video). A good start is by darkening the default grass. I did not realize it but 95% of the Videos on Chief are in X7 and X8 format now. It would be nice if you could set up "Terrain Layers" like the walls so dirt and other earth type objects can be depicted. Link to comment Share on other sites More sharing options...
