Migaloo Posted April 16, 2016 Share Posted April 16, 2016 Seems I have an issue with the brick pattern on exterior walls and foundation walls only displaying on the front and rear walls and not the side walls. Anyone else seen this? Connie and James plan.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2016 Share Posted April 16, 2016 Your plan looks great in Standard view but your same problem is showing up in Vector view. I tried swapping out the pattern file but no luck there. None or the other tools in my limited tool box worked either. Is it the colour or the pattern that is most important to display? You might want to send this one in for tech support on Monday or maybe someone more knowledgeable will take a look. Best of luck and I would be interested to know how this one gets resolved. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2016 Share Posted April 16, 2016 Only had a chance to look at your plan very briefly but I think its one for tech support. I couldn't pin it to any of the usual suspects. In fact, if you rotate the whole plan 90 degrees, the problem rotates to the other walls. Very weird. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2016 Share Posted April 16, 2016 Thanks Michael, You just isolated the problem for me so I could solve this one. If there is a change when you rotate the plan, then it is a lighting issue, or more specifically a Material Definition Problem. I have never run across this one before but if you adjust your "Shading Contrast:" to 50% then I think you will like the results. I wonder how many more years I can keep going on learning something new in Chief every day? Link to comment Share on other sites More sharing options...
Rich_Winsor Posted April 16, 2016 Share Posted April 16, 2016 Is this what you are after? I reset the material for the exterior walls of the brick entryway to "Use Default" at the top of the Plan Materials list. Then I used the eye dropper tool to paint that material onto the foundation walls. Link to comment Share on other sites More sharing options...
glennw Posted April 16, 2016 Share Posted April 16, 2016 I think the problem is that the brick joint color is the same color as the bricks once the Shading Contrast does it's magic. This results in the brick joint disappearing in the shaded areas. So, either change the brick joint color, or as Chopsaw said, change the Shading Contrast. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted April 16, 2016 Share Posted April 16, 2016 This issue seems similar to the one discussed a few weeks ago concerning backsplash tile lines not showing in vector view with colors turned on. From my investigation into that one I believe the root cause is that the generic sun adjustments do not function under this specific condition. As being suggested above the materials shading contrast control can be used to work around this. Just wondering if tech support could confirm if the inability to adjust the generic sun in vector view with color on is intended or an oversight. Graham Link to comment Share on other sites More sharing options...
Migaloo Posted April 16, 2016 Author Share Posted April 16, 2016 Thanks everyone for the help. I will try adjusting the color of the mortar joint. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 16, 2016 Share Posted April 16, 2016 Just a further thought.. When printing vector views in black and white for elevations etc. You will find that the default mortar joint colour is almost white for red brick 5 ( that I had a problem with ) and your red brick 4 that is only a little darker. So you will find when printing in B&W that you will see a blank wall unless you darken the mortar joint (Lines:) enough that they show up depending on resolution and printer settings. My experience was that the mortar joints would show on screen, and print preview, as well as in PDF, and then disappear when printed on paper. Link to comment Share on other sites More sharing options...
Solution Migaloo Posted April 16, 2016 Author Solution Share Posted April 16, 2016 Thanks for the tip. The brick and mortar was very similar in color but they were different by a shade or so. Once I went darker with the mortar the issue cleared right up. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 16, 2016 Share Posted April 16, 2016 I too considered that it might be related to lighting after my quick experiment rotating the model but I thought "Nah, I don't see how lighting could be removing lines". It never even occurred to me to check the line color (or shading contrast for that matter). Good job piecing this one together guys. Teamwork! Link to comment Share on other sites More sharing options...
