MigP74 Posted February 16, 2016 Share Posted February 16, 2016 I would like to apply a custom texture to a round dish. The image I have for the texture is square and when I apply it to the plate it doesn't show it correctly even though I have it set to stretch to fit. Is there a specific way to do this? Thanks in advance Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 16, 2016 Share Posted February 16, 2016 Stretch to fit does precisely that and nothing more. it is the resolution and size of the texture and how well its edges are trimmed that determines how it looks on an object. No other advise or comments are possible since you have not shared an image of your texture or how it looks in Chief. DJP 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 16, 2016 Author Share Posted February 16, 2016 You're right, I should have posted pictures.The plate is an already existing one from the library, and the texture is from a photo I took of a plate:Custom photo:How it appears in Chief: Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 16, 2016 Share Posted February 16, 2016 ou could try to offset the texture in the texture image dialoguw box. Don;t know if that would help. 1 Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 16, 2016 Share Posted February 16, 2016 That will be a tough one. Your jpg pic is square and the plate is round. You will likely need to take your pic and crop it round to eliminate the wood and possibly size it to as close as possible to the plate objects size. Then the stretch to fit should produce a reasonable result. Graham 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 16, 2016 Author Share Posted February 16, 2016 I have tried that and it still shows all wonky. Could it be because the plate isn't exactly a flat round disc, and has instead the shape of a plate? Or maybe because when I define the dimensions of the plate on the stand, I do so for the two things combined as I don't think there is a way to define dimensions to each separately. Link to comment Share on other sites More sharing options...
DMDesigns Posted February 16, 2016 Share Posted February 16, 2016 I took your picture & I deleted out the wood background then applied that to the Chief Plate, (the one in the middle of the picture provided) it looked ok, but then applied to the Chief upright "large plate" (the one on the far right) looked a bit better but the edges were distorted.. On the far left, it looks almost perfect when using a simple round polyline.. X8 Plan Attached. Hope that helps you out.. plate.zip 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 16, 2016 Author Share Posted February 16, 2016 Unfortunately I cannot open that as I use X2 Link to comment Share on other sites More sharing options...
DMDesigns Posted February 16, 2016 Share Posted February 16, 2016 Unfortunately I cannot open that as I use X2 You can download and unzip the file, and just take the texture out and apply it to a round polyline. Ill also attach it here. Dave 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 16, 2016 Share Posted February 16, 2016 For best results with a round texture, you need to use a .png image file that supports a transparent background. As a PNG it will work like a charm provided you eliminate the white background and make that white part transparent. DJP 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 16, 2016 Author Share Posted February 16, 2016 Thanks everyone.I had already made a PNG image with transparency around the round plate and used that.As for using a round polyline, I have thought about having to resort to it, since the plate on the library has two distinct geometrical objects like any plate should - the inner round area, and the outer, slightly raised from the centre area. That would mean I'd have to find a plate stand to go with it too Link to comment Share on other sites More sharing options...
MigP74 Posted February 17, 2016 Author Share Posted February 17, 2016 Ok, I've resigned to creating the plate from scratch as a round polyline. The texture now appears correctly when using stretch t fit.I have used the same method on a wall sculpture (created a background image to help me create a faithful polyline, dimensioned the polyline as the image, etc.). The texture appeared correctly here too. However, as soon as I moved ort rotated the sculpture, the textures went all wonky again. Any idea what is causing this?Photo of the sculpture (transparent PNG): Screenshot of how it looks now: Link to comment Share on other sites More sharing options...
DMDesigns Posted February 17, 2016 Share Posted February 17, 2016 1 Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted February 17, 2016 Solution Share Posted February 17, 2016 Hey Dave, We actually have a tool for that...Build>Image>Create Image. It's funny. I stumbled upon it a little while back while I was doing the same thing you're doing in your video. 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 17, 2016 Author Share Posted February 17, 2016 Thank you so very much for taking the time to make a video in reply to my problem. The problem is the sculpture is supposed to be hung on a wal as opposed to just stand on a surface and doing it like that would make it appear facing the camera when the wall isn't facing the camera Link to comment Share on other sites More sharing options...
DMDesigns Posted February 17, 2016 Share Posted February 17, 2016 Hey Dave, We actually have a tool for that...Build>Image>Create Image. It's funny. I stumbled upon it a little while back while I was doing the same thing you're doing in your video. Yea, I was just skipping that step, LOL... Link to comment Share on other sites More sharing options...
DMDesigns Posted February 17, 2016 Share Posted February 17, 2016 Thank you so very much for taking the time to make a video in reply to my problem. The problem is the sculpture is supposed to be hung on a wal as opposed to just stand on a surface and doing it like that would make it appear facing the camera when the wall isn't facing the camera Ok, then use Michael's Trick, Choose Build-Image-then choose Create Billboard Image 1 Link to comment Share on other sites More sharing options...
MigP74 Posted February 17, 2016 Author Share Posted February 17, 2016 Thank you so much. It works perfectly now Link to comment Share on other sites More sharing options...
MigP74 Posted February 17, 2016 Author Share Posted February 17, 2016 Here is the result Link to comment Share on other sites More sharing options...
HumbleChief Posted February 17, 2016 Share Posted February 17, 2016 Nice work you guys and great to have your energy on the forums David. I've learned so, so, much over the years from your very generous web site. Michael, I had no idea there was a build>build image tool. Nice. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 17, 2016 Share Posted February 17, 2016 ...Michael, I had no idea there was a build>build image tool. Nice. That's funny. I think I remember briefly reading about the tool back when I first started using X3 but never used it and totally forgot about it. Fast forward a few years...I was using a plant to try and get an image to always face the camera and I thought to myself..."This is stupid, how did Chief make these plants and why wouldn't they give us a way to make our own or to make 2D people images?" So I started scouring all the tools and reading the help files...and eventually stumbled on the Build Image tools. Link to comment Share on other sites More sharing options...
DMDesigns Posted February 17, 2016 Share Posted February 17, 2016 That's funny. I think I remember briefly reading about the tool back when I first started using X3 but never used it and totally forgot about it. Fast forward a few years...I was using a plant to try and get an image to always face the camera and I thought to myself..."This is stupid, how did Chief make these plants and why wouldn't they give us a way to make our own or to make 2D people images?" So I started scouring all the tools and reading the help files...and eventually stumbled on the Build Image tools. What is that they say, If you don't use it.... I'm SUPER GUILTY OF THAT...! Link to comment Share on other sites More sharing options...
DMDesigns Posted February 17, 2016 Share Posted February 17, 2016 Nice work you guys and great to have your energy on the forums David. I've learned so, so, much over the years from your very generous web site. Michael, I had no idea there was a build>build image tool. Nice. Thanks Larry - I almost forgot how much fun it was hanging out here..! Link to comment Share on other sites More sharing options...
