ED-209 Posted December 9, 2015 Share Posted December 9, 2015 Hi, I'm having trouble adding kitchen sinks; in the floor camera view the counter-top shows through the sink. The only way I can stop this is to stretch out the whole cabinet so it's one long unit, but then both the doors are about 1.5m each. I've tried changing the height, but it just takes the cabinet with it. Is there a way around this, or am I going to have to have 4ft. wide doors in all of my cabinets? Thanks Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted December 9, 2015 Share Posted December 9, 2015 Did you get the sink from Chief's library or bring it in from another source? Link to comment Share on other sites More sharing options...
Bill_Emery Posted December 9, 2015 Share Posted December 9, 2015 There is at least one sink in the library that don't cut a hole in the counter correctly. Try a different sink. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 9, 2015 Share Posted December 9, 2015 You should really attach a plan. Would answer a lot of questions. Link to comment Share on other sites More sharing options...
ED-209 Posted January 7, 2016 Author Share Posted January 7, 2016 Did you get the sink from Chief's library or bring it in from another source? It's from the main CA library, and it's still doing it. Link to comment Share on other sites More sharing options...
ED-209 Posted January 7, 2016 Author Share Posted January 7, 2016 There is at least one sink in the library that don't cut a hole in the counter correctly. Try a different sink. I've tried lots of sinks, it does it with all of them. You'd think they'd test these things before releasing software. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 7, 2016 Share Posted January 7, 2016 Post the plan so we can take a look. Link to comment Share on other sites More sharing options...
MarkMc Posted January 7, 2016 Share Posted January 7, 2016 Attached - all from the library, no changes made. Maybe heed the adivce of others. Link to comment Share on other sites More sharing options...
ED-209 Posted January 7, 2016 Author Share Posted January 7, 2016 Attached - all from the library, no changes made. Maybe heed the adivce of others. Why else would I be posting a question on a forum, if not to "heed the advice of others"? Link to comment Share on other sites More sharing options...
ED-209 Posted January 7, 2016 Author Share Posted January 7, 2016 Post the plan so we can take a look. Here you go: Link to comment Share on other sites More sharing options...
tommy1 Posted January 7, 2016 Share Posted January 7, 2016 It looks like that sink may be over multiple cabinets. Link to comment Share on other sites More sharing options...
MarkMc Posted January 7, 2016 Share Posted January 7, 2016 The "advice of others" has been to post a plan. All the image tells me is you have a problem. One thing though- where did you get that sink? I can't find a double drainboard sink in my libraries. Here is a single drainboard sink from the library. Now I have to get some work done and head to a funeral, someone else will have to help once you get around to putting up a plan. Link to comment Share on other sites More sharing options...
ED-209 Posted January 7, 2016 Author Share Posted January 7, 2016 It looks like that sink may be over multiple cabinets. It is, it's the only way to get doors underneath it. Otherwise you have to stretch out one cabinet so that the door it 2m wide, which would be highly impractical for a real house. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 7, 2016 Share Posted January 7, 2016 Adjust the front face elements of the wide cabinet by using the dbx. You can split the elements using "Split Vertical" Another way that works is to create a Custom Cabinet Top wide enough for the sink. You might have to adjust the sink location after inserting it in the custom top. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 7, 2016 Share Posted January 7, 2016 IAE, The problem is that the hole is only cut in the Counter Top. With a small cabinet the Counter Top is only as wide as the Cabinet unless you create a Custom Counter Top and stretch it to cover multiple Cabinets. Link to comment Share on other sites More sharing options...
Dermot Posted January 7, 2016 Share Posted January 7, 2016 Although sinks can span multiple cabinets, the program might not always cut the automatic counter top hole correctly. The best thing to do in this situation is to simply create your own custom counter top. The easiest way to do this is to select all connected base cabinets and then use the "Generate Custom Countertop" tool. This custom counter top should replace the automatic ones and this should give you a proper hole for your sink. I would also encourage you to report any problems you find with the automatic counter tops to technical support. If you are creating your own sink symbols, you may have to manually create your own counter top hole. Custom sink symbols will only create a rectangular hole by default. If you need any other shaped hole, you will need to create it yourself. Also, just as an FYI. You can split cabinet faces up into as many different face items as you like. Assuming that you are using Chief Architect Premier X7, you can split faces either horizontally and vertically and sub-divide them as many times as you like. It is very simple to create a single cabinet with a double or triple face. In your case, it looks like you are trying to make a sink base that is narrower then the other cabinets. This is just a guess based on your rather small picture. Since you can't make a single cabinet with multiple depths this probably won't help solve your problem. And finally, you will usually get more help if you post a simple plan demonstrating the problem. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 7, 2016 Share Posted January 7, 2016 Dermot, I appreciate you confirming what I said in Posts #14 & #15. Link to comment Share on other sites More sharing options...
