DB-Designs Posted September 21, 2015 Share Posted September 21, 2015 I am doing a bunch of interior elevations for a client. I scale down the callout to fit in each room but the text does not get any smaller. I tried to change it in defaults but it does not appear to change when I create a new callout. What am I doing wrong? Link to comment Share on other sites More sharing options...
dshall Posted September 21, 2015 Share Posted September 21, 2015 I am doing a bunch of interior elevations for a client. I scale down the callout to fit in each room but the text does not get any smaller. I tried to change it in defaults but it does not appear to change when I create a new callout. What am I doing wrong? I feel like I am walking under a bridge that has 37 men and 3 damsels poised to pour red hot burning oil on me............ but here goes,....... I know guys, I know guys, no plan, I am going against my animal instincts, this is a real stab in the dark but there goes....... the text style is controlled by TEXT STYLE and not USE LAYER FOR TEXT STYLE....... gosh, am going to get under the bridge without the wrath of 37 men and 3 damsels or will I feel the hot gooey oil pour down the nape of my neck Time will tell. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 21, 2015 Author Share Posted September 21, 2015 These are interior elevation cameras changed to callouts but still act as interior elevation cameras. I do not have the option "text style" when I open one of these up. I see the option "callout size" and when I change that, only the arrow and circle changes size but not the text. When I change the text height in the callout specifications, is does not change the text in these camera displays. I have the text height in the callout specifications set at 1" but it still shows at 4 1/2" in the callouts. Link to comment Share on other sites More sharing options...
dshall Posted September 21, 2015 Share Posted September 21, 2015 Nuts, that oil is hot,,,,,,, I had a feeling I was not going to be successful without a plan....... Link to comment Share on other sites More sharing options...
DB-Designs Posted September 21, 2015 Author Share Posted September 21, 2015 I'm confused. You need a copy of the plan i'm working on? Link to comment Share on other sites More sharing options...
dshall Posted September 21, 2015 Share Posted September 21, 2015 I'm confused. You need a copy of the plan i'm working on? Yes. If you can't figure it out and the plan is in front of you, what are the chances of me figuring it out without the plans in front of me? I already took one stab at a solution and I failed miserably. Do you want me to keep guessing until I get it right or would you mind posting the plan so I can help you out in one quick shot? I swear, 90% of the time if I try to help somebody out without a plan, I end up spending 15 minutes instead of 4 minutes solving THEIR problem. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 21, 2015 Share Posted September 21, 2015 I would suggest calling Chief Architect Support - assuming that you have SSA. Otherwise, open the "Object Layers" tool on the Edit Toolbar and see what text styles are being used there. One of them is probably controlling the text size. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 21, 2015 Author Share Posted September 21, 2015 Yes. If you can't figure it out and the plan is in front of you, what are the chances of me figuring it out without the plans in front of me? I already took one stab at a solution and I failed miserably. Do you want me to keep guessing until I get it right or would you mind posting the plan so I can help you out in one quick shot? I swear, 90% of the time if I try to help somebody out without a plan, I end up spending 15 minutes instead of 4 minutes solving THEIR problem. Are you for real? I'm just looking for a little help while I try to learn this program. Don't you have Chief Architect? How hard is it for you to draw 4 walls, highlight the interior, create room elevation views and change the wall elevation camera to a callout in plan display. Because that's all I'm doing. And then when I change the callout size the text doesn't change. I even tried it in a brand new drawing file. It appears somebody else might have provided a simple solution that I GREATLY appreciate!!! And as it turns out, it was a simple solution! If you feel I was wasting your time with this post, then don't waste my time with your mumbling nonsense responses about "walking under a bridge that has 37 men and 3 damsels poised to pour red hot burning oil on me"......as you put it. 1 4 Link to comment Share on other sites More sharing options...
dshall Posted September 21, 2015 Share Posted September 21, 2015 Are you for real? I'm just looking for a little help while I try to learn this program. Don't you have Chief Architect? How hard is it for you to draw 4 walls, highlight the interior, create room elevation views and change the wall elevation camera to a callout in plan display. Because that's all I'm doing. And then when I change the callout size the text doesn't change. I even tried it in a brand new drawing file. It appears somebody else might have provided a simple solution that I GREATLY appreciate!!! And as it turns out, it was a simple solution! If you feel I was wasting your time with this post, then don't waste my time with your mumbling nonsense responses about "walking under a bridge that has 37 men and 3 damsels poised to pour red hot burning oil on me"......as you put it. I apologize for wasting your time, it won't happen again. 5 Link to comment Share on other sites More sharing options...
Greg_NY61 Posted September 21, 2015 Share Posted September 21, 2015 You need to highlight the text in order to change text size... You cannot change text size without having the text highlighted. Link to comment Share on other sites More sharing options...
Ginkgohouse Posted September 21, 2015 Share Posted September 21, 2015 Ok - Lets wrap this up your camera labels( 1. ) are not set to automatic personally i do not use the automatic text below line as I will typically have the same camera on a couple of pages and it make the label too big. Make sure to click ( 2. ) automatic Then the label sizes are driven by the Cameras ( 3. ) - Text Style ( 4. ) Which is edited in saved text styles ( 5. ) and & ( 6. ) So - If you push the plan at 1/4" the camera callouts will automatically be at 4" then when you change the layer set and push, as say 1/2" you change the "Text Style" to 1/2" text style. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 21, 2015 Share Posted September 21, 2015 A quick video... http://screencast.com/t/PAsgE5rl 1 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 21, 2015 Share Posted September 21, 2015 These are interior elevation cameras changed to callouts but still act as interior elevation cameras. I do not have the option "text style" when I open one of these up. I see the option "callout size" and when I change that, only the arrow and circle changes size but not the text. When I change the text height in the callout specifications, is does not change the text in these camera displays. I have the text height in the callout specifications set at 1" but it still shows at 4 1/2" in the callouts. I'm confused. You need a copy of the plan i'm working on? Are you for real? I'm just looking for a little help while I try to learn this program. Don't you have Chief Architect? How hard is it for you to draw 4 walls, highlight the interior, create room elevation views and change the wall elevation camera to a callout in plan display. Because that's all I'm doing. And then when I change the callout size the text doesn't change. I even tried it in a brand new drawing file. It appears somebody else might have provided a simple solution that I GREATLY appreciate!!! And as it turns out, it was a simple solution! If you feel I was wasting your time with this post, then don't waste my time with your mumbling nonsense responses about "walking under a bridge that has 37 men and 3 damsels poised to pour red hot burning oil on me"......as you put it. Please bear in mind that there are a huge number of variables that come into play. People like Scott donate many many many hours to help people like you and I sort through their problems and it is extremely common for the OP to miscommunicate what exactly they are doing or to overlook any number of variables or settings that may come into play. In this example, Scott took 10 minutes of his time trying to solve your issue not realizing you were using cameras...something he would have known if you had attached the plan. Its just a good idea to get into the habit of attaching the plan (even a stripped down version with just enough information top show your problem). It takes a ton of the guesswork out and saves everyone a lot of time. Link to comment Share on other sites More sharing options...
DB-Designs Posted September 21, 2015 Author Share Posted September 21, 2015 Please bear in mind that there are a huge number of variables that come into play. People like Scott donate many many many hours to help people like you and I sort through their problems and it is extremely common for the OP to miscommunicate what exactly they are doing or to overlook any number of variables or settings that may come into play. In this example, Scott took 10 minutes of his time trying to solve your issue not realizing you were using cameras...something he would have known if you had attached the plan. Its just a good idea to get into the habit of attaching the plan (even a stripped down version with just enough information top show your problem). It takes a ton of the guesswork out and saves everyone a lot of time. I understand and I will remember this next time. I was just asking questions because I was confused by his mumbling nonsense. He made it clear that he wastes a lot of his time on other peoples "problems". He would have saved a lot of his time and my time if he would have just said "attach the plan" or not even responded at all because there was no plan attached. 1 Link to comment Share on other sites More sharing options...
DB-Designs Posted September 21, 2015 Author Share Posted September 21, 2015 Thank you everybody......for all the help!!!! Link to comment Share on other sites More sharing options...
MickeyToo Posted September 21, 2015 Share Posted September 21, 2015 Good video, Michael. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 21, 2015 Share Posted September 21, 2015 Thanks Mickey. Its just a crappy video (a hommage to Scott's "crappy" ray traces) but hopefully it helped someone. I've only made a few but I've quickly realized that I learn a lot simply making one and often times what I learn or what someone else may learn watching them may have absolutely zero to do with the subject matter. 1 Link to comment Share on other sites More sharing options...
MickeyToo Posted September 21, 2015 Share Posted September 21, 2015 I've only made a few but I've quickly realized that I learn a lot simply making one... If you have ever taught, you know how true that statement is. Your video was clear and to the point. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 22, 2015 Share Posted September 22, 2015 All of my text is controlled in the layerset for quick access. I never have that problem. Scott is actually a very nice guy, he really wants to help you, but doesn't want to spend all day guessing at it. Link to comment Share on other sites More sharing options...
katiebits Posted November 21, 2018 Share Posted November 21, 2018 On 9/21/2015 at 2:37 PM, Alaskan_Son said: A quick video... http://screencast.com/t/PAsgE5rl Thank you for this video! Completely helped me learn something new today! Link to comment Share on other sites More sharing options...
