HumbleChief Posted September 8, 2015 Share Posted September 8, 2015 I thought I was able to solve this at one time but it's reared it's head again. The CalCerts watermark is superimposing itself over the information in the T24 report. Any suggestions? Link to comment Share on other sites More sharing options...
dshall Posted September 8, 2015 Share Posted September 8, 2015 I have never seen it.... I bet it is from your T-24 person. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 8, 2015 Share Posted September 8, 2015 3 questions come to mind... 1. Does CA even support semitransparent watermarks? 2. Have you tried printing that page to see how it prints? 3. Have you tried doing a save as PDF to see if that works? Link to comment Share on other sites More sharing options...
johnny Posted September 8, 2015 Share Posted September 8, 2015 PDF's a couple (few) years back switched from having raster images only (though broken up) to "vector" mixed with raster AND multi-layer support. I can tell you in VW we have a option to import the PDF as a bitmap or as vector - which solves this issue. I dont have CA in front of me, but perhaps that same option is on the import window..... Otherwise, if you have a copy of Acrobat Pro or Photoshop you can open the PDF and then save again as bitmap only. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 8, 2015 Share Posted September 8, 2015 There are PDF Editors that can be used to remove watermarks. I use "Power PDF Advanced" by Nuance. If the PDF was saved as an "Editable PDF" I can open it and remove any watermarks, notes, etc and make whatever modifications I need. I have the option at that point to replace the prior version or save it with a new name. Link to comment Share on other sites More sharing options...
Doug_Park Posted September 8, 2015 Share Posted September 8, 2015 Please make sure our support team has a copy of the PDF that doesn't work. It seems like it should work, and may indeed work on the Mac but not Windows due to better support of PDFs at the OS level. Thanks for pointing this out. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 8, 2015 Author Share Posted September 8, 2015 Thank you and sorry, got busy and had to leave the office. The issue got resolved in a way that does't address the issue. It turns out I don't need Calcerts on this T24 page so the logo/watermark doesn't appear on the final copy. Doesn't resolve the issue in the OP and I'll make sure support gets a copy of the original PDF for testing. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 8, 2015 Author Share Posted September 8, 2015 Here's a previous set of PDF's from the same T24 guy and they display fine so he/we must have changed something in the way they were created to get them to mis-behave. Link to comment Share on other sites More sharing options...
