HumbleChief Posted August 28, 2015 Share Posted August 28, 2015 ...and how do I get rid of it? Link to comment Share on other sites More sharing options...
Solution HumbleChief Posted August 28, 2015 Author Solution Share Posted August 28, 2015 Found it - It's a wall finish, delete the exterior wall layer in the wall definition and it disappears. Can I now please call this the best answer? He!! yeah. 1 Link to comment Share on other sites More sharing options...
johnny Posted August 28, 2015 Share Posted August 28, 2015 Nice - thank you larry that was driving me nuts. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 28, 2015 Share Posted August 28, 2015 Your welcome Link to comment Share on other sites More sharing options...
Kbird1 Posted August 28, 2015 Share Posted August 28, 2015 I see this happen sometimes when I change a Deck to a Porch or Slab Room (a Def. with a Conc. Floor slab) and usually just change the exterior wall finish to Concrete to match.... and put it down to another CA "quirk" Link to comment Share on other sites More sharing options...
dshall Posted August 29, 2015 Share Posted August 29, 2015 I see this happen sometimes when I change a Deck to a Porch or Slab Room (a Def. with a Conc. Floor slab) and usually just change the exterior wall finish to Concrete to match.... and put it down to another CA "quirk" Can you duplicate this behavior now or is it sporadic? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 29, 2015 Share Posted August 29, 2015 most recently in Dickerchen's Plan ,that you also looked at here : https://chieftalk.chiefarchitect.com/index.php?/topic/6337-why-doesnt-framing-display-in-plan-view/#entry56451 The front porch is labeled a balcony and I changed it to porch and deck etc. after pulling the retaining wall back to see what was wrong with it and the wall behind it. That Plan was done in X2 originally but I see it frequently as I help over on HT and see all sorts of weird happenings Link to comment Share on other sites More sharing options...
dshall Posted August 29, 2015 Share Posted August 29, 2015 most recently in Dickerchen's Plan ,that you also looked at here : https://chieftalk.chiefarchitect.com/index.php?/topic/6337-why-doesnt-framing-display-in-plan-view/#entry56451 The front porch is labeled a balcony and I changed it to porch and deck etc. after pulling the retaining wall back to see what was wrong with it and the wall behind it. That Plan was done in X2 originally but I see it frequently as I help over on HT and see all sorts of weird happenings I removed front stairs, left stairs on both sides, changed room from balcony to porch and this is what I get... expected behavior. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 29, 2015 Share Posted August 29, 2015 Hmmm the Other Front Door on the LH Side.... the one with the retaining wall, is where it happened to me... but I've never been able to figure out a particular step or set of things to make it happen. The retaining wall is slightly imbedded into the "Porch" and the front (only) stairs are too , so I slide the RT Wall out 2-3 inches and pulled it back and just looked at your Front stair and So maybe it is a View issue ? I am in Full Overview Perspective Nope same in Full Camera The other quirks maybe a X2 to X7 issue? if I change the Balcony to a Porch It still frames , rather than give me a 4" slab (same for a Court) so change it to a Deck and let it frame, then back to a Porch and I get 4" slab and framing ...just can't win.. Mac vs PC maybe? Link to comment Share on other sites More sharing options...
dshall Posted August 29, 2015 Share Posted August 29, 2015 Hey Mick, if interested, we can do a quick go to meeting to hash this out. Send me your email, I will send invite, we can do a short GTM to see if we agree what we are seeing, and we can spend some time bashing Joe and Glenn. dscotthall@mac.com Link to comment Share on other sites More sharing options...
Kbird1 Posted August 30, 2015 Share Posted August 30, 2015 Sorry Scott , I minimised the Browser this morning and was busy Drawing up an As-Built from a measure I did Thurs. , so I had something ready for a Client Meeting today , so didn't see this till now... In this particular case I had the thought , that the Balcony setting maybe causing the issue , those I have seen the Issue Like Larry showed on numerous occasions but can't duplicate right now and HC didn't post his plan in the OP to try. M. Link to comment Share on other sites More sharing options...
dshall Posted August 30, 2015 Share Posted August 30, 2015 Sorry Scott , I minimised the Browser this morning and was busy Drawing up an As-Built from a measure I did Thurs. , so I had something ready for a Client Meeting today , so didn't see this till now... In this particular case I had the thought , that the Balcony setting maybe causing the issue , those I have seen the Issue Like Larry showed on numerous occasions but can't duplicate right now and HC didn't post his plan in the OP to try. M. No Problem Mick. Hoping to connect with you, maybe next time. I think you and I are seeing it a little differently, maybe we can connect at a different time. If I was missing something, I was thinking you could set me straight. Link to comment Share on other sites More sharing options...
