Stairs with a Volute at the bottom?
Electromen
Go to solution Solved by lbuttery,
Hi , not sure where I got this or if it will work but attached is the Volute I have.
Apologies to the original author but I can't credit you with it's creation as I don't remember.
The forum doesn't allow calibz files to be posted so I changed the extension to .zip so change it back and import as usual.
Volute.zip
