fcwilt Posted June 9 Share Posted June 9 (edited) Hi, The title is my question: I am trying to learn how to use the layout features in X17. While doing so I was getting unexpected results when sending a plan or elevation view to the layout. It turned out that the Drawing Sheet Scale was NOT the same for all views. So I set about to make them all the same desired value but I could not find a way to do them at once. I had to select File/Print/Drawing Sheet Setup for each plan/view. It seems that there should be a way to set them all in one operation. Yes? No? Thanks. Frederick Edited June 9 by fcwilt Link to comment Share on other sites More sharing options...
GeneDavis Posted June 9 Share Posted June 9 You specify scale when sending a view to layout. A layout page can contain a number of views, and each has its own scale. Select any view on a page, and there's a tool for editing its scale. Have you worked with this tool? 1 Link to comment Share on other sites More sharing options...
fcwilt Posted June 9 Author Share Posted June 9 (edited) Yes I found that capability. My case involved a number of plan and elevation views, in the plan file, which had many different scales - and that was due to a mistake on my part. I was hoping there was an easy way to reset them all to the setting I desired - other than doing one at a time - which I ended up doing. Thanks for the replay. Frederick Edited June 9 by fcwilt Link to comment Share on other sites More sharing options...
robdyck Posted June 10 Share Posted June 10 On 6/8/2026 at 6:11 PM, fcwilt said: It seems that there should be a way to set them all in one operation. I have often wished for this capability but it does not exist. All newly created section or elevation views will inherit the drawing sheet that is active in plan view. So, let's say you want to create all your interior wall elevations at 1/2" scale and you'd like the drawing sheet set properly. In plan view, change the drawing sheet size and scale to suit your preferred elevation views. Create all your interior elevation views. Now, you can change the plan view drawing sheet back to what is intended for the majority of your plan views. For all existing elevation or section views, the drawing sheet must be changed manually as needed. This is a bit of a nuisance if you frequently use multiple sheet sizes like I do. My default is Arch D sheets (36"x24") but I have several customers that require Tabloid (17"x11") so I often need to change the drawing sheet for all the existing elevation cameras, one at a time. It's an annoying waste of time. 1 Link to comment Share on other sites More sharing options...
fcwilt Posted June 10 Author Share Posted June 10 Thanks very much for the reply. Knowing that new elevations/cross sections inherit from the active plan view is the part I was missing. Frederick 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 10 Share Posted June 10 4 hours ago, robdyck said: My default is Arch D sheets (36"x24") but I have several customers that require Tabloid (17"x11") so I often need to change the drawing sheet for all the existing elevation cameras, one at a time. It's an annoying waste of time. curious, why don't you just scale when printing ? or does that not work On 6/8/2026 at 7:36 PM, fcwilt said: I was hoping there was an easy way to reset them all to the setting I desired - other than doing one at a time - which I ended up doing. I rescale them in layout, one layout box at a time 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 10 Share Posted June 10 (edited) It would be real nice if there were default settings for: Plan Views Exterior Elevations Interior Elevations Cross Sections CAD Details Where we could specify the scale and maybe even the drawing sheet size. Edited June 11 by Joe_Carrick 1 Link to comment Share on other sites More sharing options...
