MegLee Posted 21 hours ago Share Posted 21 hours ago (edited) Why is my ADU shows 500 sqft TOTAL on the drawing provided by my designer?! What caused this discrepancy? Designer said that's the software generated numbers and that there're "layers I couldn't see"....! And that nothing he can do! 12'5"W X 38'L = 475 shown on detailed drawing - including exterior walls These 2 numbers have to match in permit application. Appreciate any feedback! Thanks!!! Edited 21 hours ago by MegLee Too wordy Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 20 hours ago Share Posted 20 hours ago Impossible to say for certain what's going on without a plan file, or some plan view images with dimensions at a bare minimum. Link to comment Share on other sites More sharing options...
MegLee Posted 20 hours ago Author Share Posted 20 hours ago Michael, appreciate your reply, please comment upon checking the plan sent to your mail. Link to comment Share on other sites More sharing options...
Chrisb222 Posted 19 hours ago Share Posted 19 hours ago 1 hour ago, MegLee said: Why is my ADU shows 500 sqft TOTAL on the drawing provided by my designer?! What caused this discrepancy? No clue. See attached, these are "software generated numbers" derived from an OOB factory Chief Architect template file: What software is your designer using? Link to comment Share on other sites More sharing options...
MegLee Posted 19 hours ago Author Share Posted 19 hours ago Here's the Plan which shows the measurements discrepancies. Plans.pdf Link to comment Share on other sites More sharing options...
Chrisb222 Posted 19 hours ago Share Posted 19 hours ago 4 minutes ago, MegLee said: Here's the Plan which shows the measurements discrepancies. So I showed that the software generates accurate numbers. This is a question for your designer. 2 hours ago, MegLee said: nothing he can do Sure there is. Change 500 to 472. Link to comment Share on other sites More sharing options...
basketballman Posted 18 hours ago Share Posted 18 hours ago Use an area polyline to be sure ... never lies .. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted 18 hours ago Share Posted 18 hours ago Maybe there's a pony wall about 2" thicker that isn't being displayed on the plan. Then if the measurements are to the exterior of that wall you would get the discrepancy. We would need the actual Chief plan file - not a pdf - in order to know exactly. Link to comment Share on other sites More sharing options...
MegLee Posted 18 hours ago Author Share Posted 18 hours ago Designer's explanation:"All areas mentioned on the right side of page one are accurate and calculated from exterior walls (including all sheathing). That's how the city calculates and that's how the areas are put in.""I have done few rounds of check on my end and confident with the answers and the calculation areas I provided. There are specific ways of measuring & I believe what you are inputting doesn't count all the dimensional layers. You do not see those in the drawings and therefore assumptions are made." Why can he provide formula, numbers to arrive at his conclusion? Measurements on the drawing have to match the total on permit application, right? I saw one which matches exactly. And, how often does one see for-sale houses or ADU listed exactly at 2000, 800 or 500 sqft? Link to comment Share on other sites More sharing options...
JKEdmo Posted 17 hours ago Share Posted 17 hours ago 21 minutes ago, MegLee said: Designer's explanation:"All areas mentioned on the right side of page one are accurate and calculated from exterior walls (including all sheathing). That's how the city calculates and that's how the areas are put in.""I have done few rounds of check on my end and confident with the answers and the calculation areas I provided. There are specific ways of measuring & I believe what you are inputting doesn't count all the dimensional layers. You do not see those in the drawings and therefore assumptions are made." Why can he provide formula, numbers to arrive at his conclusion? Measurements on the drawing have to match the total on permit application, right? I saw one which matches exactly. And, how often does one see for-sale houses or ADU listed exactly at 2000, 800 or 500 sqft? Discussion between you and your designer. Explain your concerns and have him demonstrate how he calculated these areas. That can be done graphically with a polyline that shows the actual area. He should be able to do that quickly. Link to comment Share on other sites More sharing options...
SHCanada2 Posted 17 hours ago Share Posted 17 hours ago something is missing for information. For the ADU, using the measurements on the plan, which look to go to the framing, it is 722 sq ft. his plan says 750. The perimeter is 137 ft, so the ft "missing around the permiter" is 750-722=28 sq ft divided by 137 ft, which is 0.2ft or 2.4" all the way around. maybe that is the cladding and sheathing, but if it is I'm not sure what it would be, you would have to see the rest of the plans Link to comment Share on other sites More sharing options...
MegLee Posted 16 hours ago Author Share Posted 16 hours ago (edited) My neighbor's permit application shows the detail measurements match exactly the total. See red only. IMG_8132.heic Edited 16 hours ago by MegLee Link to comment Share on other sites More sharing options...
SHCanada2 Posted 16 hours ago Share Posted 16 hours ago sorry I cannot view a heic file. What is your proposed cladding for the ADU, and what is the thickness? Link to comment Share on other sites More sharing options...
MegLee Posted 16 hours ago Author Share Posted 16 hours ago Link to comment Share on other sites More sharing options...
MegLee Posted 16 hours ago Author Share Posted 16 hours ago I thought all along these totals are entered manually. And again, how often does one see for-sale houses or ADU listed exactly at 2000, 800 or 500 sqft? Link to comment Share on other sites More sharing options...
SHCanada2 Posted 16 hours ago Share Posted 16 hours ago (edited) that does not match the uploaded pdf earlier which shows: are we talking the same thing here? Edited 16 hours ago by SHCanada2 Link to comment Share on other sites More sharing options...
