builtright3 Posted 5 hours ago Share Posted 5 hours ago Wall Types I was trying to come up with a wall type for my new walls that will show when I print in black and white. I thought maybe dots would work but when I print, it doesn’t show the dots. I don’t like solid black walls. I prefer gray but it doesnt show up when print in black and white. I have to print in color or grey scale Any Ideas, Anyone? Link to comment Share on other sites More sharing options...
builtright3 Posted 4 hours ago Author Share Posted 4 hours ago I just used angle hatching for now. Seems to work fine at 1" or 3/4 when I print black and white. Link to comment Share on other sites More sharing options...
Rookie65 Posted 3 hours ago Share Posted 3 hours ago I use a solid color for existing walls, then use some of the geometric shapes, etc. for other wall type fill. You can use whatever color you want, yet obviously dark ones print best. It helps when labeling the wall types on the drawing so you know what types are where. I don't know if Chief will let you adjust the size and angle of the shapes, yet that helps to in separating them. 1 Link to comment Share on other sites More sharing options...
