Rich_Winsor Posted June 30, 2025 Share Posted June 30, 2025 So I downloaded and installed X17. I opened a simple plan I had handy. When I opened a Perspective Full Overview Camera my rig started to labor. The fans started running full blast and the system temps took off. It took a long time to generate a simple Standard image and when it did this is what I got. Has anybody else been getting this behavior? 3 1 Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted June 30, 2025 Share Posted June 30, 2025 My first guess would be that sometimes with a new install you need to re-adjust your power settings. Make sure its not set to "Power Saving" and set to "Performance" Maybe? Link to comment Share on other sites More sharing options...
HumbleChief Posted June 30, 2025 Share Posted June 30, 2025 Perhaps check for any nearby volcanos or lava flows in the area? Link to comment Share on other sites More sharing options...
NRST8TRKR Posted June 30, 2025 Share Posted June 30, 2025 Meltdown Link to comment Share on other sites More sharing options...
JKEdmo Posted June 30, 2025 Share Posted June 30, 2025 32 minutes ago, NRST8TRKR said: Meltdown Link to comment Share on other sites More sharing options...
Doug_N Posted June 30, 2025 Share Posted June 30, 2025 You should also avoid vinyl siding, as when exposed to higher temperatures, well you know the result... 1 Link to comment Share on other sites More sharing options...
Steve-C Posted July 1, 2025 Share Posted July 1, 2025 1 Link to comment Share on other sites More sharing options...
para-CAD Posted July 1, 2025 Share Posted July 1, 2025 VINYL SIDING Jobsite fire in the winter in Clarksville TN...2005 Yep....that day sucked Link to comment Share on other sites More sharing options...
Doug_N Posted July 2, 2025 Share Posted July 2, 2025 On 7/1/2025 at 5:09 AM, para-CAD said: VINYL SIDING Jobsite fire in the winter in Clarksville TN...2005 Yep....that day sucked Nice colour though... 1 Link to comment Share on other sites More sharing options...
