Rich_Winsor Posted 23 hours ago Share Posted 23 hours ago So I downloaded and installed X17. I opened a simple plan I had handy. When I opened a Perspective Full Overview Camera my rig started to labor. The fans started running full blast and the system temps took off. It took a long time to generate a simple Standard image and when it did this is what I got. Has anybody else been getting this behavior? 3 Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted 18 hours ago Share Posted 18 hours ago My first guess would be that sometimes with a new install you need to re-adjust your power settings. Make sure its not set to "Power Saving" and set to "Performance" Maybe? Link to comment Share on other sites More sharing options...
HumbleChief Posted 17 hours ago Share Posted 17 hours ago Perhaps check for any nearby volcanos or lava flows in the area? Link to comment Share on other sites More sharing options...
NRST8TRKR Posted 14 hours ago Share Posted 14 hours ago Meltdown Link to comment Share on other sites More sharing options...
JKEdmo Posted 14 hours ago Share Posted 14 hours ago 32 minutes ago, NRST8TRKR said: Meltdown Link to comment Share on other sites More sharing options...
Doug_N Posted 10 hours ago Share Posted 10 hours ago You should also avoid vinyl siding, as when exposed to higher temperatures, well you know the result... Link to comment Share on other sites More sharing options...
Steve-C Posted 1 hour ago Share Posted 1 hour ago Link to comment Share on other sites More sharing options...
