winterdd Posted Monday at 02:58 PM Share Posted Monday at 02:58 PM Howdy guys, is there a way to show a door with no casing AND mounted to the center of a wall? Link to comment Share on other sites More sharing options...
DBCooper Posted Monday at 03:19 PM Share Posted Monday at 03:19 PM See if adjusting the "panel offset" does what you want. Link to comment Share on other sites More sharing options...
winterdd Posted Monday at 03:32 PM Author Share Posted Monday at 03:32 PM 12 minutes ago, DBCooper said: See if adjusting the "panel offset" does what you want. The only panel offset option I saw had to do with floor clearance and overall height of door but I did see this but it cannot be checked, hmmmmm Link to comment Share on other sites More sharing options...
GeneDavis Posted Monday at 03:39 PM Share Posted Monday at 03:39 PM Did you try a pony wall there, the one OOB that is called shower wall, and making an end to end door? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Monday at 03:57 PM Share Posted Monday at 03:57 PM 24 minutes ago, winterdd said: The only panel offset option I saw had to do with floor clearance and overall height of door but I did see this but it cannot be checked, hmmmmm Its on the General tab Link to comment Share on other sites More sharing options...
winterdd Posted Monday at 03:58 PM Author Share Posted Monday at 03:58 PM 18 minutes ago, GeneDavis said: Did you try a pony wall there, the one OOB that is called shower wall, and making an end to end door? Gotta have a full wall there per owner request, this exact shower. Link to comment Share on other sites More sharing options...
winterdd Posted Monday at 04:01 PM Author Share Posted Monday at 04:01 PM 2 minutes ago, Alaskan_Son said: Its on the General tab This where I was looking but that doesn't change what I want unless I am looking at the wrong thing. I won't make a big deal about it though and just add a note if I have too. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Monday at 04:10 PM Share Posted Monday at 04:10 PM 8 minutes ago, winterdd said: This where I was looking but that doesn't change what I want unless I am looking at the wrong thing. I won't make a big deal about it though and just add a note if I have too. I see. You must still be back in X15. Link to comment Share on other sites More sharing options...
winterdd Posted Monday at 04:20 PM Author Share Posted Monday at 04:20 PM 9 minutes ago, Alaskan_Son said: I see. You must still be back in X15. Yeah, I upgrade every two years.......... Link to comment Share on other sites More sharing options...
GeneDavis Posted Monday at 08:51 PM Share Posted Monday at 08:51 PM I do the door with its handle side closing to all-glass adjacent, so the continuous seal lip strip has a common surface for its seal fin. The down-low spout you see is called a toe-tester. You go into the shower, close the door, open the valve, which results in water coming from spout and not showerhead. Run it until your toes say just perfect warm, and press the diverter button. You can buy toe tester spouts two ways, one with diverter in the spout, the other without diverter. I specify without, and a shower control with a button diverter. 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted yesterday at 09:47 AM Share Posted yesterday at 09:47 AM Nice Gene. We've had a couple clients install those a little higher to fill/rinse mop buckets. Link to comment Share on other sites More sharing options...
robdyck Posted 22 hours ago Share Posted 22 hours ago 17 hours ago, GeneDavis said: Run it until your toes say just perfect warm Makes sense...for people with no hands. Shouldn't the diverter be much lower on the wall so they don't have to lift their foot so high to run it on? Not everyone does yoga! Just when you think you've seen it all! Don't forget to lower the shower door handle by about 30". Link to comment Share on other sites More sharing options...
