winterdd Posted March 10 Share Posted March 10 Howdy guys, is there a way to show a door with no casing AND mounted to the center of a wall? Link to comment Share on other sites More sharing options...
DBCooper Posted March 10 Share Posted March 10 See if adjusting the "panel offset" does what you want. Link to comment Share on other sites More sharing options...
winterdd Posted March 10 Author Share Posted March 10 12 minutes ago, DBCooper said: See if adjusting the "panel offset" does what you want. The only panel offset option I saw had to do with floor clearance and overall height of door but I did see this but it cannot be checked, hmmmmm Link to comment Share on other sites More sharing options...
GeneDavis Posted March 10 Share Posted March 10 Did you try a pony wall there, the one OOB that is called shower wall, and making an end to end door? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10 Share Posted March 10 24 minutes ago, winterdd said: The only panel offset option I saw had to do with floor clearance and overall height of door but I did see this but it cannot be checked, hmmmmm Its on the General tab Link to comment Share on other sites More sharing options...
winterdd Posted March 10 Author Share Posted March 10 18 minutes ago, GeneDavis said: Did you try a pony wall there, the one OOB that is called shower wall, and making an end to end door? Gotta have a full wall there per owner request, this exact shower. Link to comment Share on other sites More sharing options...
winterdd Posted March 10 Author Share Posted March 10 2 minutes ago, Alaskan_Son said: Its on the General tab This where I was looking but that doesn't change what I want unless I am looking at the wrong thing. I won't make a big deal about it though and just add a note if I have too. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10 Share Posted March 10 8 minutes ago, winterdd said: This where I was looking but that doesn't change what I want unless I am looking at the wrong thing. I won't make a big deal about it though and just add a note if I have too. I see. You must still be back in X15. Link to comment Share on other sites More sharing options...
winterdd Posted March 10 Author Share Posted March 10 9 minutes ago, Alaskan_Son said: I see. You must still be back in X15. Yeah, I upgrade every two years.......... Link to comment Share on other sites More sharing options...
GeneDavis Posted March 10 Share Posted March 10 I do the door with its handle side closing to all-glass adjacent, so the continuous seal lip strip has a common surface for its seal fin. The down-low spout you see is called a toe-tester. You go into the shower, close the door, open the valve, which results in water coming from spout and not showerhead. Run it until your toes say just perfect warm, and press the diverter button. You can buy toe tester spouts two ways, one with diverter in the spout, the other without diverter. I specify without, and a shower control with a button diverter. 1 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted March 11 Share Posted March 11 Nice Gene. We've had a couple clients install those a little higher to fill/rinse mop buckets. Link to comment Share on other sites More sharing options...
robdyck Posted March 11 Share Posted March 11 17 hours ago, GeneDavis said: Run it until your toes say just perfect warm Makes sense...for people with no hands. Shouldn't the diverter be much lower on the wall so they don't have to lift their foot so high to run it on? Not everyone does yoga! Just when you think you've seen it all! Don't forget to lower the shower door handle by about 30". Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 14 Share Posted March 14 A present Robs Shower Link to comment Share on other sites More sharing options...
winterdd Posted March 17 Author Share Posted March 17 On 3/14/2025 at 2:42 PM, Renerabbitt said: A present Robs Shower The file could not be downloaded. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 17 Share Posted March 17 Came through for me using X16. It is a symbol and @Renerabbitt is being coy by shipping it that way. He should give you an X15 .plan file so you can open it, since you are not on X16. I can view and use the symbol, but as a symbol it's essentially a locked-up 3D object and we cannot see how he built it. Further, I don't believe symbols will report materials. Link to comment Share on other sites More sharing options...
DBCooper Posted March 17 Share Posted March 17 So the easy way to solve this is to use X16 where you can just offset the panel to be where you want it in the opening. I did not take a look at Rene's symbol but my guess is that he made the door into a symbol so that he could offset the origin of the symbol. Personally, if I was determined to do this in X15 or some other older version, I would probably just create a doorway and manually place the door and position it how I wanted it. Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 17 Share Posted March 17 2 hours ago, GeneDavis said: Came through for me using X16. It is a symbol and @Renerabbitt is being coy by shipping it that way. He should give you an X15 .plan file so you can open it, since you are not on X16. I can view and use the symbol, but as a symbol it's essentially a locked-up 3D object and we cannot see how he built it. Further, I don't believe symbols will report materials. It's a cabinet so you can open it up and see all of the parameters of it, and I did not see that Rob was in X15. i built this in X16 and is part of a whole system that I would not redo in X15 1 hour ago, DBCooper said: I did not take a look at Rene's symbol you should Link to comment Share on other sites More sharing options...
winterdd Posted March 18 Author Share Posted March 18 20 hours ago, Renerabbitt said: and I did not see that Rob was in X15. i built this in X16 and is part of a whole system that I would not redo in X15 you should Thanks anyway Rene, I will upgrade this year. My biggest holdup is my library getting exported so I don't lose anything. I haven't mastered that yet and is always an issue. Link to comment Share on other sites More sharing options...
