Custom Railings
winterdd
34 minutes ago, winterdd said:
does CA offer these type of railings
Rob,
I made a similar custom infill panel for my project.  You could too.  It was fairly quick.
Trying to remember the specifics -- create the panel with linework, convert to 3D solid, then convert to library symbol as a millwork object.  Lastly, select panel for your railing.
Jim
image.thumb.png.c353b74aa38403fba373397a39365b2d.pngimage.thumb.png.ca2a51367a9c6e46687306011108dca4.png
The picture on close inspection is a cable railing with 2x4's set inside of the cables.
I would suggest using the cable railing panels in the library and make the 2x4's in a cross section out of 3d solids as you first mention. Then block them and move into position in plan view.
It's not difficult to use an existing symbol of cable railing, add the cross pieces, and create a new millwork symbol to use as a panel. I'd create the cross pieces and the border using a molding in hopes that woodgrain will apply correctly if you ever need a wood material for the panel.
