cbucks Posted February 10, 2024 Share Posted February 10, 2024 Curious everyone's opinion on this whether this will be something will regret? Link to comment Share on other sites More sharing options...
rgardner Posted February 10, 2024 Share Posted February 10, 2024 15 minutes ago, cbucks said: Curious everyone's opinion on this whether this will be something will regret? Makes it that much harder to move furniture or larger items. Add in the winder stairs and it makes it even harder. I personally don't like to do stairs narrower than 39" and prefer 42... FWIW 1 Link to comment Share on other sites More sharing options...
cbucks Posted February 10, 2024 Author Share Posted February 10, 2024 Thanks definitely a concern Link to comment Share on other sites More sharing options...
Doug_N Posted February 10, 2024 Share Posted February 10, 2024 It would be really important to talk to a code expert about the winders doing 180 degrees. Most authorities only allow 90 degrees. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 10, 2024 Share Posted February 10, 2024 What you show in that image is illegal in the US and Canada. Link to comment Share on other sites More sharing options...
javatom Posted February 10, 2024 Share Posted February 10, 2024 IRC code would require 6" as the narrowest point of the tread. The stair you show has 0". Link to comment Share on other sites More sharing options...
GeneDavis Posted February 10, 2024 Share Posted February 10, 2024 And yet it's seen in plenty of photos of homes for sale. Link to comment Share on other sites More sharing options...
Doug_N Posted February 11, 2024 Share Posted February 11, 2024 Here is the code for winders in stairs in Canada (using the Ontario Building Code version). Here is what the code says about the narrow end of tapered stairs (as in winders). Ontario Building Code - Volume 1, O. Reg. 332/12, Article 9.8.4.3. of Division B 9.8.4.3. Dimensions for Tapered Treads (1) Except as provided in Sentence (2) and Articles 9.8.4.5. and 9.8.4.5A., tapered treads shall have a run that, (a) is not less than 150 mm (5-7/8") at the narrow end of the tread, and (b) complies with the dimensions for rectangular treads specified in Table 9.8.4.1. when measured at a point 300 mm (11-13/16") from the centre line of the inside handrail. (2) Tapered treads in required exit stairs shall conform to the requirements in Article 3.4.6.9. (3) The depth of a tapered tread shall be not less than its run at any point and not more than its run at any point plus 25 mm . Ontario Building Code - Volume 1, O. Reg. 332/12, Article 9.8.4.5. of Division B 9.8.4.5. Winders A-9.8.4.5. Winders. (1) Stairs within dwelling units are permitted to contain winders that converge to a centre point provided,(a) the winders turn through an angle of not more than 90°, (b) individual treads turn through an angle of not less than 30° or not more than 45°, and (c) adjacent winders turn through the same angle.(2) Where more than one set of winders described in Sentence (1) is provided in a single stairway between adjacent floor levels, such winders shall be separated in plan by at least 1 200 mm (47 -1/4"). Link to comment Share on other sites More sharing options...
