ericepv Posted October 13, 2023 Share Posted October 13, 2023 Does anyone have any tips on the best way to add a valley to a roof? I seem to recall seeing a post on this awhile back but I haven't been able to find it. Link to comment Share on other sites More sharing options...
basketballman Posted October 13, 2023 Share Posted October 13, 2023 One thing I do is increase the line weight so everything is easier to see Also make sure facia heights on the adjacent roof planes are same .. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 13, 2023 Share Posted October 13, 2023 2 hours ago, ericepv said: Does anyone have any tips on the best way to add a valley to a roof? I seem to recall seeing a post on this awhile back but I haven't been able to find it. Am I to assume you mean in 3D for accurate renderings ? If so you will need to remove the shingles from your roof definition and add them along with the flashings manually so they can be adjusted just the way you like in the valleys and or eaves. Link to comment Share on other sites More sharing options...
Chrisb222 Posted October 13, 2023 Share Posted October 13, 2023 2 hours ago, ericepv said: Does anyone have any tips on the best way to add a valley to a roof? I seem to recall seeing a post on this awhile back but I haven't been able to find it. You don't mean a cricket do you? I'm a little confused by your question. I don't know that we actually "add" a valley, they are simply the result of two perpendicular planes... A screenshot with some notes would be helpful... Link to comment Share on other sites More sharing options...
Solution glennw Posted October 13, 2023 Solution Share Posted October 13, 2023 It sounds like you are talking about for 3D views. This is from a post of mine from a while back. This can be done fairly easily - with a proviso that the valley actually sits on top of the roof surface. This doesn't seem to be noticeable in the 3D views that I played with. You can make Chief draw the 3D Polylines that hold the valley profile - the same way that it builds Ridge Caps - but it takes 2 steps. Build your roof. Add a Ridge Cap to the valleys by selecting a roof edge and turning On, Ridge Cap On Selected Edge. Select the valley 3D Polylines and place them on their own layer. Rebuild the roof - Chief will build all the hips and ridges and also display the valleys you created. Quote 5 1 Link to comment Share on other sites More sharing options...
ericepv Posted October 14, 2023 Author Share Posted October 14, 2023 Thanks Glenn, that's exactly what I needed. Link to comment Share on other sites More sharing options...
mthd97 Posted March 25, 2024 Share Posted March 25, 2024 On 10/14/2023 at 8:47 AM, glennw said: It sounds like you are talking about for 3D views. This is from a post of mine from a while back. This can be done fairly easily - with a proviso that the valley actually sits on top of the roof surface. This doesn't seem to be noticeable in the 3D views that I played with. You can make Chief draw the 3D Polylines that hold the valley profile - the same way that it builds Ridge Caps - but it takes 2 steps. Build your roof. Add a Ridge Cap to the valleys by selecting a roof edge and turning On, Ridge Cap On Selected Edge. Select the valley 3D Polylines and place them on their own layer. Rebuild the roof - Chief will build all the hips and ridges and also display the valleys you created. Quote Nice work @glennw, would it still work by pulling the edges of the valley away a bit from the valley line and then creating a sloping molding profile so you can lower it ? Link to comment Share on other sites More sharing options...
