CAD Pattern Question
JKEdmo
Good morning,
I am trying to use the CAD / Patterns / Create New Pattern tool in order to create a new grid pattern with fine dashed lines.
My goal:
a 12x12 grid of fine dashed hatch pattern to represent existing ceiling tile to be removed on a ceiling demolition plan.  (I have created polylines with fill hatch patterns to represent these dropped ceilings).
My problem:
Whenever I create the new pattern, the CAD linework reverts to by layer (continuous).  The desired fine dash linestyle does not "stick."  From what I can tell, the CAD pattern tool only allows continuous lines (grrr).  Any ideas what I'm doing wrong?
Thanks once again,
Jim
8 minutes ago, Chopsaw said:
It might be possible to find a cad fill pattern that works or make one but chief does not seem to have one.
Thank you.
CS, do you have any insight into why Chief won't allow creating a custom pattern with anything other than a continuous linetype?
Jim
Possibly just too many options and no specific requests.  Same problem with 2D Cad Blocks it seems.
Ok, thanks for confirming.  I'll try to make a request / suggestion.
Jim
On 9/1/2023 at 6:24 AM, rlackore said:
You can create a Pattern by manually drawing the dashes with individual CAD lines
Thanks for the library Robert ....
but it seems chief has another 1/2 finished "new feature"  if it only allows solid line types ?   ( or is it a possible Hatch generation Issue?)
On 9/5/2023 at 9:40 AM, rlackore said:
This is expected by now, isn't it? Most Chief "new features" seem to need more time in the oven.
True, however I find the half baked new features very helpful in spite of not being fully baked. The real problem it seems is that most seem to never finish being baked.
