BUILD UP MOLDING
mtldesigns
I am trying to figure out how to build up (or stack up) molding.  Meaning, I want two or three moldings combined as one.  Mainly need for lintels, for windows and doors, since the dbx won't let you build them like you can in a room molding dbx.
Will be suggesting this when I am done here.
I am certainly not a trim expert but it seems to work for me. Rooms allow multiple moldings and multiple profiles for each molding but a molding polyline also allows multiple profiles and then you can use multiple molding lines.  Not sure I understand what the issue is ?
Rpadge's method works. Another workaround is to place a temporary object that supports "Make Stack" in the dialog, such as a cabinet or a molding polyline. Add the moldings you would like, select them both (Ctrl + Click), and click "Make Stack". You can add that to the library and then use it for your windows and doors.
Made you a quick video showing you how easy this is;
CA15 - Creating a Custom Stacked Molding - Watch Video
Thank you all..  Had a storm roll through and had no power for a bit today, is why I am replying so late.  I think underground lines in my subdivision must be water logged because for some reason this year the power shuts off even during a mild shower.. at least it seams that way.
I can do that Chop, I was asking in particular for when I am in a door or window dbx..
21 hours ago, Rpadge said:
profiles in a cad detail
I know how to do this, but your answer Robert and that vid you made Steve, cleared some things up, PLUS it will aide to others.  I blame the heat for not being clear in my OP.  What I was trying to ask or maybe wonder for a future suggestion if it was possible to have the door and window specification dbx have the options to add-change or delete and stack molding.  Without having to create a saved profile or 4 piece stack molding part like Steve showed.  We can do this in the room specifications under molding tab, is why I ask.
