Brandon_1311 Posted August 11, 2023 Share Posted August 11, 2023 Wondering if anybody is able to tell me how to do this... I am trying to create a room under the stairs, and I would like to have an angled wall under the stairs to close it in. I want the bottom of the wall to follow along the stairs, but can't seem to get it? I created a wall along here, but have no options that I can see to make it follow the stairs. I can make it follow the stairs on the top side, like a railing, but cannot figure out how to do it below. Any ideas?? I am using Home designer pro 2019 (Build: 20.3.0.54x64) Thanks to anyone with some ideas on this! Link to comment Share on other sites More sharing options...
GeneDavis Posted August 11, 2023 Share Posted August 11, 2023 Home Designer has its own forum. This is Chief Architect Premier, and most of us are clueless as to how HD works. Link to comment Share on other sites More sharing options...
dshall Posted August 11, 2023 Share Posted August 11, 2023 On 8/11/2023 at 3:54 PM, Brandon_1311 said: Wondering if anybody is able to tell me how to do this... I am trying to create a room under the stairs, and I would like to have an angled wall under the stairs to close it in. I want the bottom of the wall to follow along the stairs, but can't seem to get it? I created a wall along here, but have no options that I can see to make it follow the stairs. I can make it follow the stairs on the top side, like a railing, but cannot figure out how to do it below. Any ideas?? I am using Home designer pro 2019 (Build: 20.3.0.54x64) Thanks to anyone with some ideas on this! Expand Put a typical wall in and the put in a doorway or window no sash the shape of the opening (angled top) 1 Link to comment Share on other sites More sharing options...
Randino Posted September 8, 2023 Share Posted September 8, 2023 On 8/11/2023 at 6:04 PM, dshall said: Put a typical wall in and the put in a doorway or window no sash the shape of the opening (angled top) Expand I have a similar problem. When I place a doorway, how do I make the the top of the door follow the stringer? My doorway, and window, are square across the top. thanks in advance Link to comment Share on other sites More sharing options...
dshall Posted September 8, 2023 Share Posted September 8, 2023 On 9/8/2023 at 12:59 PM, Randino said: I have a similar problem. When I place a doorway, how do I make the the top of the door follow the stringer? My doorway, and window, are square across the top. thanks in advance Expand My mistake..... do not use a doorway.... use a pass thru window.... I believe I have requested the ability to shape a door..... Link to comment Share on other sites More sharing options...
Randino Posted September 9, 2023 Share Posted September 9, 2023 I created an Cross Section/Elevation Drew a polyline on the wal Snapped top two corners of the polyline to the stinger. grabed bottom edg of wall and drugged it up close to the top of the poly line Then used the parallel tool. Link to comment Share on other sites More sharing options...
dshall Posted September 9, 2023 Share Posted September 9, 2023 Yep, and then to finish off underside of wall a ceiling plane will work. No perfect solution. pick your poison. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted September 9, 2023 Share Posted September 9, 2023 Hope no one tall needs to use that urinal. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 9, 2023 Share Posted September 9, 2023 that would not work for me, I'm as tall as the door, I would pee all over the walls. Link to comment Share on other sites More sharing options...
Chrisb222 Posted September 9, 2023 Share Posted September 9, 2023 On 9/9/2023 at 3:59 PM, DRAWZILLA said: that would not work for me, I'm as tall as the door, I would pee all over the walls. Expand Losing your distance ability, or your aim?? 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 9, 2023 Share Posted September 9, 2023 both 1 Link to comment Share on other sites More sharing options...
