How do I make an angled half wall under stairs?
Brandon_1311
Wondering if anybody is able to tell me how to do this... I am trying to create a room under the stairs, and I would like to have an angled wall under the stairs to close it in. I want the bottom of the wall to follow along the stairs, but can't seem to get it? I created a wall along here, but have no options that I can see to make it follow the stairs. I can make it follow the stairs on the top side, like a railing, but cannot figure out how to do it below.
Any ideas??
I am using Home designer pro 2019 (Build: 20.3.0.54x64)
Thanks to anyone with some ideas on this!
Any ideas??
Put a typical wall in and the put in a doorway or window no sash the shape of the opening (angled top)
  • 4 weeks later...
I have a similar problem. When I place a doorway, how do I make the the top of the door follow the stringer? My doorway, and window, are square across the top.
thanks in advance
thanks in advance
My mistake.....  do not use a doorway....  use a pass thru window....  I believe I have requested the ability to shape a door.....
I created an Cross Section/Elevation
Drew a polyline on the wal
Snapped top two corners of the polyline to the stinger.
grabed bottom edg of wall and drugged it up close to the top of the poly line
Then used the parallel tool.
