GeneDavis Posted July 25, 2023 Share Posted July 25, 2023 I made the mistake of starting a new job using the wrong template file, got way into it with the modeling, i.e. building, and realized I was missing a lot of things I wanted. So I did an edit all area all floors and copied the plan, then pasted it into my preferred template file. The terrain and elevation data did not copy in. What am I missing? Link to comment Share on other sites More sharing options...
rgardner Posted July 25, 2023 Share Posted July 25, 2023 37 minutes ago, GeneDavis said: I made the mistake of starting a new job using the wrong template file, got way into it with the modeling, i.e. building, and realized I was missing a lot of things I wanted. So I did an edit all area all floors and copied the plan, then pasted it into my preferred template file. The terrain and elevation data did not copy in. What am I missing? It will come over as a polyline you can then convert to a terrain perimeter. Link to comment Share on other sites More sharing options...
CharlesVolz Posted July 25, 2023 Share Posted July 25, 2023 Here is something that I worked up for a client recently. I hope that it may help someone. Best, Charles Terrain - Copy, Paste, Move, Rotate - Notes & Layerset.pdf 2 Link to comment Share on other sites More sharing options...
Chrisb222 Posted July 25, 2023 Share Posted July 25, 2023 What's "wrong" with the wrong template? If it's things that can be imported like saved plan views, layer sets, etc, that might be easier / less rework. Link to comment Share on other sites More sharing options...
onfire2000 Posted October 8, 2023 Share Posted October 8, 2023 This is helpful thanks! Once you copy/paste your terrain and reassign it to the terrain perimeter, how to you place the house plan on top (change the elevation to match) the terrain elevation? When I slide the terrain under my house plan, it cuts the house at the wrong elevation. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 8, 2023 Share Posted October 8, 2023 12 minutes ago, onfire2000 said: Once you copy/paste your terrain and reassign it to the terrain perimeter, how to you place the house plan on top (change the elevation to match) the terrain elevation? When I slide the terrain under my house plan, it cuts the house at the wrong elevation. There is a setting in the Terrain Specifications that moves the terrain relative to the subfloor height that will move the entire terrain. However if you are doing an actual terrain I like to set that at 0" and make all the terrain settings relative to the subfloor level. Link to comment Share on other sites More sharing options...
