Draw interior basement walls with auto foundation?
Jambruins
  • 3 months later...
There really isn't a way to do this, just don't jump into working on your basement if you're not at or near 100% on the main floor footprint.
Keeping Auto Foundation on is only really good for monopours, IMO. Once you start doing your own thing, it'll get turned off and then making sure your foundation walls align with the first floor walls becomes a manual chore.
Though using the Reference Display and Align w/ Above/Below tools make it fairly easy.
  • 2 years later...
The foundation is automatically drawn based on the house exterior walls above. Once it's drawn from that, what would auto foundation need to do differently? The interior walls you want would have nothing to do with the exterior walls
What does that have to do with interior walls in the basement? I do wish everything you drew in the basement wouldn't disappear if you do rebuild the foundation. Guess we're stuck with manually drawing changed foundation walls. Or just align them.
Edited by Rookie65
Add words
Do a full set of house plans including interior walls in the basement, then the customer says, move this exterior wall, and that one, change the garage size, etc.
If auto rebuild stayed on and operated per the request above by jambruins (and myself), it would move the basement exterior walls,  but leave the basement interior walls. Then I would go and adjust the interior walls to match the moved exterior found walls.
today CA truns off auto rebuild foundation when one draws interior walls in the basement, so instead I have to go put on the reference display, and move the exterior basement walls to match the main floor, and then use the align tool to make sure they really do match.
So the request is, unless I misinterpreted, is for CA to allow auto rebuild foundations to stay on when I draw interior walls in the basement, and, CA would move the foundation walls to match the main floor (just like it would do if I did not have any interior walls in the basement)
If I had no interior walls in the basement, then autorebuild foundation could stay on. That is dependency on interior walls
Edited by SHCanada2
My guess is because the interior walls are not part of a foundation, when rebuilding foundation the interior walls are not recognized, and therefore disappear. Aligning the foundation to exterior wall changes is not that difficult a process
It's like trying to make 2 independent functions become one. It won't remember your interior walls when trying to rebuild the foundation. Depending on how many walls are involved, could you possibly copy what you want to save, then rebuild the foundation, and "paste-hold position" the interior walls back?
  • 3 weeks later...
Chief still doesn’t allow Auto Rebuild Foundation to stay on once you draw interior walls in the basement. As soon as you add manual walls on the foundation level, Auto Foundation turns off because a rebuild would delete anything you drew manually.
Right now the only workaround is to keep Auto Foundation off and use Reference Display + Align w/ Above/Below when the main floor changes. Otherwise you can copy the interior walls, rebuild, then paste-hold-position.
If you want this behavior changed, it really needs to go in as a feature request to Chief.
Edited by mittalmitalesh
