QualicoreHomes Posted April 17, 2023 Share Posted April 17, 2023 Is this a possibility in Chief? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 17, 2023 Share Posted April 17, 2023 Not using a standard Garage Door. You could create a Symbol and insert it in a Doorway, but that's the only way I can think of at this time. It's similar to the approach I used for a Roll-up Garage Door. You would probably need a 2D Block showing it in the closed position for Plan Views. Link to comment Share on other sites More sharing options...
rgardner Posted April 17, 2023 Share Posted April 17, 2023 Assuming this is for a rendering it would require a custom Door panel that is doable but definitely will take some work. Use a Tall Cabinet with a custom top hinged door with the sections you want to see open as the door. Here is a VERY QUICK version of it with two doors shown just to give you the idea. You would need to have on a separate layer set/layer turned off with another one that shows it closed. Also requires a doorway as Joe mentions. Link to comment Share on other sites More sharing options...
QualicoreHomes Posted April 18, 2023 Author Share Posted April 18, 2023 Interesting, thanks for the replies and pointing me in a direction, much appreciated!! Link to comment Share on other sites More sharing options...
Archnot-Boltz Posted April 18, 2023 Share Posted April 18, 2023 How about making it a request.? All the programmers would have to do is modify a bi-fold and rotate it 90 degrees. Link to comment Share on other sites More sharing options...
MarkMc Posted April 18, 2023 Share Posted April 18, 2023 Why not make the symbol from a bifold door to begin with. Set as fixture interior, inserts into wal, rotate symbol. Add a door way. Still need two symbols on seperate layers but ... Plan with door used to make symbol and open symbol in doorway. Still need to make other symbol vert bifold.zip 1 Link to comment Share on other sites More sharing options...
rgardner Posted April 18, 2023 Share Posted April 18, 2023 8 minutes ago, MarkMc said: Why not make the symbol from a bifold door to begin with. Set as fixture interior, inserts into wal, rotate symbol. Add a door way. Still need two symbols on seperate layers but ... Plan with door used to make symbol and open symbol in doorway. Still need to make other symbol vert bifold.zip 772.44 kB · 0 downloads This was what I was implying to for making the cabinet doors above using the bifold doors as the starting point. But going direct to making it a symbol is a great way too. Link to comment Share on other sites More sharing options...
Archnot-Boltz Posted April 18, 2023 Share Posted April 18, 2023 Very Nice Mark, but it would still be nice to have in the door tools and not have to do the work a round. Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 19, 2023 Share Posted April 19, 2023 I did marks suggestion here, Link to comment Share on other sites More sharing options...
QualicoreHomes Posted April 19, 2023 Author Share Posted April 19, 2023 Thanks everyone for your help, it is much appreciated! As I was busy with Mark's suggestion and couldn't figure out how to rotate the symbol, Rene's video came in and got us to the finish line. I ended up making 2 separate doors on different layers, 1 open and 1 closed for the different views. I really like how you go over the Q & A in your video Rene, I will continue to check that out. Thanks again for all the help!! Link to comment Share on other sites More sharing options...
