capitaldesigns Posted January 22, 2023 Share Posted January 22, 2023 When drawing a patio/porch with concrete slab, how do you get the conc. slab to extend past the posts by 6" to 12" ? I am working on a patio where I am using 6x6 posts on an 18"x18" stone base. 6" of the stone base is off the slab. Thanks, Mike Link to comment Share on other sites More sharing options...
Doug_N Posted January 22, 2023 Share Posted January 22, 2023 Hi Michael. Please post the plan file so that people can see the problem and suggest a method or work around to achieve your desired design. Link to comment Share on other sites More sharing options...
ValleyGuy Posted January 22, 2023 Share Posted January 22, 2023 I feel your pain. I do the same as Solver suggests, I draw a complete slab or add a border slab around the room slab that CA generates. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2023 Share Posted January 22, 2023 4 hours ago, capitaldesigns said: I am working on a patio where I am using 6x6 posts on an 18"x18" stone base. 6" of the stone base is off the slab. Depends on your particular situation , it can be as simple as making the wall type defining the Porch the same width as the columns ie 18" in your case..... this is because Chief ALWAYS centers "Newel Post" on the Wall. make it 20" wide if you don't want the columns right at the edge etc. M. 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 22, 2023 Share Posted January 22, 2023 19 minutes ago, Kbird1 said: Depends on your particular situation , it can be as simple as making the wall type defining the Porch the same width as the columns ie 18" in your case..... this is because Chief ALWAYS centers "Newel Post" on the Wall. Good tip. This will also align the beam above, centered on the wall / column. If the beam is the same width as the 6x6 column it will all align nicely 19 minutes ago, Kbird1 said: make it 20" wide if you don't want the columns right at the edge etc. M. In that case I add a 1-1/2" concrete layer to both the exterior and interior layers of the wall definition, creates the typical lip automatically. Link to comment Share on other sites More sharing options...
capitaldesigns Posted January 23, 2023 Author Share Posted January 23, 2023 Thanks for the suggestions. I will try that today. Link to comment Share on other sites More sharing options...
builtright3 Posted January 23, 2023 Share Posted January 23, 2023 Depending on your situation, changing the wall thickness can cause other complications like how your tie in will look. I will usually do the wall thickness same as the beam size. For the bigger columns you may need to do a lower slab to build your foundation and an upper 4" slab if you want the 1 1/2" overhang. You have a lot more control this way and its fast and easy. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted January 3, 2025 Share Posted January 3, 2025 Please support the request below to update the porch floor... Link to comment Share on other sites More sharing options...
