Barrel Ceiling
RobUSMC
I have searched this new forum and have not found anything. I am trying to find out the best way to draw a barrel ceiling. Has anyone designed one. I'm thinking maybe a polyline solid somehow?? Maybe someone can let me know the best route and steps.
Thanks
Rob
If you want to show framing you will have to go with a ceiling plane. Now will CA do it correctly is a whole other story.
That is what I think.  But if you think about it,  the framing will be going the wrong way.  I would still be inclined to go with the ceiling plane as you suggest,  and I suppose we could then put in BLOCKING to represent the rafters,   have not tried it,  but it seems like it would work.
The reason that I suggested a poly solid over a ceiling plane is that a ceiling plane doesn't have the Facet Angle setting like a roof plane, so the ceiling plane tends to show the facets.
With a poly solid you can achieve a smoother curve.
    32609
    organiccrack
    organiccrack
