QualicoreHomes Posted November 11, 2022 Share Posted November 11, 2022 With this system, are your still pressing 2 or 3 buttons to go from one action to another? For example; If I'm on the "main" screen and I want to draw an exterior wall it be one button to go to walls and then one more to select which type of wall. Then if I want to draw a door in that wall I would have push the back button to go to the main screen, the opening button and then the type of door, so that be 3. Do you find you are pushing a lot of buttons for one action? Are the hot keys not faster as I don't have to go back to the main screen etc? I would be sold if there was one big screen/device with all the commands that I need on there. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2022 Author Share Posted November 11, 2022 1 minute ago, QualicoreHomes said: With this system, are your still pressing 2 or 3 buttons to go from one action to another? For example; If I'm on the "main" screen and I want to draw an exterior wall it be one button to go to walls and then one more to select which type of wall. Then if I want to draw a door in that wall I would have push the back button to go to the main screen, the opening button and then the type of door, so that be 3. Do you find you are pushing a lot of buttons for one action? Are the hot keys not faster as I don't have to go back to the main screen etc? I would be sold if there was one big screen/device with all the commands that I need on there. Your analysis of how the system works is correct. It's both unfortunate and fortunate that there isn't a Stream Deck with hundreds of buttons. More buttons would make a much larger unit and it would cost proportionally more The graphic buttons can process any place from 1 - 100 (or maybe more) in a single button press. Chief's Hotkeys can have 1-4 keystrokes (and if using Ctrl, Shift, Alt) there are even more than 4 Remembering complex Hotkeys is always a problem. Chief has the potential to have over 1000 Hotkeys - assuming you wanted to replace all the Toolbar icon mouse picks with Hotkey assignments. The StreamDeck buttons are much easier to see and understand than Toolbar icons. That's true even without Tooltips which can in fact be added. In the final analysis, Even with the "Back" button it's still a lot faster. I tend to draw all my Walls first, then Doors and Windows, etc. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 12, 2022 Share Posted November 12, 2022 i actually like the stream deck much better than finding the tools in a toolbar or dropdown, less clicks for me for sure. Link to comment Share on other sites More sharing options...
OkcDesigner Posted November 13, 2022 Share Posted November 13, 2022 I agree with Perry, stream deck much better then hunting down tool bars. Link to comment Share on other sites More sharing options...
5FT-20Designs Posted November 13, 2022 Share Posted November 13, 2022 Nice setup Joe. I need to create default profile for all my programs; but it won’t be so extensive as yours. Chief is my default now. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 13, 2022 Author Share Posted November 13, 2022 31 minutes ago, 5FT-20Designs said: Nice setup Joe. I need to create default profile for all my programs; but it won’t be so extensive as yours. Chief is my default now. Create a Default Profile that includes a button to launch each of your Apps. For Chief you can have a button that uses Hotkey "win+#" so that if you just make Chief the active App. I have Chief as the 4th App on my Taskbar so that button is Hotkey win+4 Link to comment Share on other sites More sharing options...
Smn842 Posted November 13, 2022 Share Posted November 13, 2022 Although expensive, you can have multiple StreamDeck XLs and if you add another its trivial to copy the layouts across. I bought a second as backup in case of failure as its proved so important for my work (not Chief as just a DIYer here) but I decided I may as well use it and it works well. I've tried having one per hand, but settled on my non dominant hand having both and that works well for the various applications I use. Link to comment Share on other sites More sharing options...
Charles Posted November 15, 2022 Share Posted November 15, 2022 On 11/12/2022 at 5:38 AM, DRAWZILLA said: i actually like the stream deck much better than finding the tools in a toolbar or dropdown, less clicks for me for sure. Your statement just sold me on getting one of these.... Now I have to decide if the brand new "Stream Deck +" will be more functional with Chief than the XL. https://www.elgato.com/en/stream-deck-plus Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 15, 2022 Author Share Posted November 15, 2022 2 hours ago, Charles said: Your statement just sold me on getting one of these.... Now I have to decide if the brand new "Stream Deck +" will be more functional with Chief than the XL. https://www.elgato.com/en/stream-deck-plus Charles, The Plus would be great for a sound studio but the XL is the way to go for Chief. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted November 16, 2022 Share Posted November 16, 2022 Link to comment Share on other sites More sharing options...
para-CAD Posted November 7, 2025 Share Posted November 7, 2025 Only $49 US gets you a lifetime StreamDeck mobile license. If it's buttons you want.....the mobile license works on a tablet and gives you 64 buttons. In split screen, you double that to 128 buttons. Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted November 13, 2025 Share Posted November 13, 2025 On 11/6/2022 at 9:23 PM, Joe_Carrick said: Here's the latest view of my Stream Deck Setup. I've extensively modified the icons for the buttons to be as close to Chief's Toolbars as I could make them. is there a limit to how many nestled folders the steam deck can have? (A folder inside a folder inside a folder) Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 13, 2025 Author Share Posted November 13, 2025 (edited) 36 minutes ago, ComputerMaster86 said: is there a limit to how many nestled folders the steam deck can have? (A folder inside a folder inside a folder) I don't know what the limit is. You can have multiple "Profiles" with at least 10 "Pages" and each button can have 32 actions which depending on the action can have additional "Pages" or actions which include "Folders". So for practical purposes there's no limit. It's extremely flexible in how you set it up. My preference is to utilize multiple "Profiles" even within Chief. Edited November 13, 2025 by Joe_Carrick 1 Link to comment Share on other sites More sharing options...
E-Elkins Posted yesterday at 09:26 PM Share Posted yesterday at 09:26 PM On 10/11/2022 at 2:43 PM, Joe_Carrick said: Joe are you still Saling chief architect Stream Deck icons ? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted yesterday at 10:51 PM Author Share Posted yesterday at 10:51 PM (edited) What do you want ? the set of icons for Chief $50.00 my complete StreamDeck XL setup for Chief $275.00 What version of Chief are you using Edited yesterday at 11:22 PM by Joe_Carrick Link to comment Share on other sites More sharing options...
E-Elkins Posted yesterday at 10:54 PM Share Posted yesterday at 10:54 PM 2 minutes ago, Joe_Carrick said: What do you want ? the set of icons for Chief my complete StreamDeck XL setup for Chief What version of Chief are you using x17 and the complete StreamDeck XL setup for Chief Link to comment Share on other sites More sharing options...
Joe_Carrick Posted yesterday at 11:30 PM Author Share Posted yesterday at 11:30 PM 29 minutes ago, E-Elkins said: What version of Chief are you using x17 and the complete StreamDeck XL setup for Chief I'm currently selling it for $275.00 I accept payment via my Venmo account Joseph-Carrick-6 - Once I've received payment I will need a couple of days to put the package together and email it to you. Link to comment Share on other sites More sharing options...
para-CAD Posted 2 hours ago Share Posted 2 hours ago This is Stream Deck Mobile with 64 buttons and if you dual screen on the iPad, you could have 128 buttons. And it only costs $49 for a lifetime license so that's probably the cheapest way to get the most out of Stream Deck. You can probably do everything that Joe would sell you, but I promise it will take so many hours that it's worth your time to make money designing and let Joe build it for you. Link to comment Share on other sites More sharing options...
