vertical metal siding
SHCanada2
7 hours ago, jasonn1234 said:
thanks!
the picture is from a pdf, I was just playing around with materials in CA, trying to replicate it
I doubt you'll be able to.  My guess is that its either a crappy texture where the top and bottom of the image don't align and therefor don't properly tile, or that the problem is with the model itself and that what you think is a single surface is actually multiple surfaces that aren't on the same plane.
looking at the zoom in'd  one, I think you are right, but I dont think I have to make the same mistake they did, I'm going to try the tile and make it metallic and see if that is close enough. Below left doesnt look like they pieced it together
On 9/22/2022 at 8:48 PM, glennw said:
Something like this?
i do not think it is that bumpy. it just looks like flat metal T&G'd together (or the appearance of T&G)
