DRAWCO Posted September 6, 2022 Share Posted September 6, 2022 I need a stucco fill style. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 6, 2022 Share Posted September 6, 2022 Add a sand fill to the stucco material Link to comment Share on other sites More sharing options...
DRAWCO Posted September 6, 2022 Author Share Posted September 6, 2022 1 hour ago, DRAWZILLA said: Add a sand fill to the stucco material Link to comment Share on other sites More sharing options...
DRAWCO Posted September 6, 2022 Author Share Posted September 6, 2022 I tried that but it did not work. Link to comment Share on other sites More sharing options...
DRAWCO Posted September 6, 2022 Author Share Posted September 6, 2022 The city wants my 2d elevations to show stucco. I tried downloading AutoCAD pat files but cannot convert them Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 6, 2022 Share Posted September 6, 2022 just add a sand pattern to your stucco material, it will show in vector views Link to comment Share on other sites More sharing options...
Kbird1 Posted September 6, 2022 Share Posted September 6, 2022 23 hours ago, DRAWZILLA said: Add a sand fill to the stucco material Also what I did to my Stucco material , just make sure to space it out , quite a bit, or the elevations will look too dark and also slow Chief down possibly . *Add this Pattern to the Stucco material if not there already......... M. Link to comment Share on other sites More sharing options...
joey_martin Posted September 6, 2022 Share Posted September 6, 2022 1 hour ago, DRAWCO said: I tried that but it did not work. You probably just need to adjust the color and scale to get the "sand" fill to show up. Link to comment Share on other sites More sharing options...
DRAWCO Posted September 6, 2022 Author Share Posted September 6, 2022 i TRIED ALL OF THESE BUT NO LUCK SO i JUST ADDED LARGE DOTS. 2 Link to comment Share on other sites More sharing options...
mtldesigns Posted September 6, 2022 Share Posted September 6, 2022 2 hours ago, DRAWCO said: The city wants my 2d elevations to show stucco Just curious, but why? Wouldn't a note or a patch section you draw manually in the 2D view and hatch be suffice? Link to comment Share on other sites More sharing options...
DRAWCO Posted September 7, 2022 Author Share Posted September 7, 2022 I am in AZ and every city and town are different. Also, I have to deal with engineers. They can be picky. Link to comment Share on other sites More sharing options...
joey_martin Posted September 7, 2022 Share Posted September 7, 2022 11 hours ago, DRAWCO said: i TRIED ALL OF THESE BUT NO LUCK SO i JUST ADDED LARGE DOTS. My next guess is that you are using the wrong camera, or you have patterns turned off on the vector view camera you are using. Without a screen shot or something more we can't help you. This is 100% a user issue though because that fill is set for stucco by default. It's there. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted September 7, 2022 Share Posted September 7, 2022 I've got 2 stucco fills. One for existing construction and one for new. Had them for so long can't exactly remember how they were created but here's a plan file that might help and a pic of what they look like in vector elevation. Hope that might help. stucco fill 1.plan Link to comment Share on other sites More sharing options...
DRAWCO Posted September 7, 2022 Author Share Posted September 7, 2022 THANK YOU Link to comment Share on other sites More sharing options...
DRAWCO Posted September 7, 2022 Author Share Posted September 7, 2022 I do not see any place to turn on patterns on the vector view. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 7, 2022 Share Posted September 7, 2022 23 minutes ago, DRAWCO said: I do not see any place to turn on patterns on the vector view. there are 2-3 places to do it and you may need to toggle more than 1 depending on what you have done.... Link to comment Share on other sites More sharing options...
HumbleChief Posted September 7, 2022 Share Posted September 7, 2022 Must be something that's on by default on my system but I found a tool to toggle on/off patterns that you can add to your tool bar. I just added it to mine. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 7, 2022 Share Posted September 7, 2022 1 minute ago, Kbird1 said: there are 2-3 places to do it and you may need to toggle more than 1 depending on what you have done.... Nice Mick, had no idea those options were available. Mine are on by default I guess as I've never had a need to not have patterns show. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 7, 2022 Share Posted September 7, 2022 3 minutes ago, HumbleChief said: Nice Mick, had no idea those options were available. Mine are on by default I guess as I've never had a need to not have patterns show. I guess I added it many moons ago? I've been using a custom toolbar for years..... as from your post it sounds like it is not normally there... M. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 7, 2022 Share Posted September 7, 2022 1 minute ago, Kbird1 said: I guess I added it many moons ago? I've been using a custom toolbar for years..... as from your post it sounds like it is not normally there... M. Yeah something I never needed to add, and will probably not use as I never turn off patterns but good to know. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 7, 2022 Share Posted September 7, 2022 5 minutes ago, HumbleChief said: Yeah something I never needed to add, and will probably not use as I never turn off patterns but good to know. I mostly use it now and again for turning them off so I can see better if the view is heavy on PATTERNS, eg Cedar Sidewall Shingles , Roofing etc M. Link to comment Share on other sites More sharing options...
DRAWCO Posted September 7, 2022 Author Share Posted September 7, 2022 Thanks I checked and patterns are on. I think the problem is that when I look at a vector view the stucco does not seem to have a pattern. The roof shingles, brick, and others do. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 7, 2022 Share Posted September 7, 2022 9 minutes ago, DRAWCO said: I think the problem is that when I look at a vector view the stucco does not seem to have a pattern That's what we were trying to tell you to do up above....... add it..... use the Material Definition Tool ( looks like a Rainbow , top right usually ) click on the stucco material and on the Pattern Tab set the Pattern to Sand and a 12" spacing.... M. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 7, 2022 Share Posted September 7, 2022 23 hours ago, DRAWCO said: I need a stucco fill style. Leo please post a/the plan you are having trouble with so we at least have a chance of helping. Link to comment Share on other sites More sharing options...
DRAWCO Posted September 7, 2022 Author Share Posted September 7, 2022 Got it. Now how can I make it stand out more? I tried making the line style larger but doesn't seem to make a difference. Link to comment Share on other sites More sharing options...
