CV-reno Posted June 3, 2022 Share Posted June 3, 2022 (edited) I've struggled for hours to figure what's wrong with a particular wall (plan attached). The attached images give a clue that something is wrong. Image 3 shows that the front to back wall doesn't meet the 90° front wall although it appears to do so in plan view (attic level). Image 2 shows different colors for the wall in PBR even though they are the same (CA is not happy about something for sure). Images 1 & 5 show a rafter that isn't cut as the adjoining rafters are. Image 4 is a PBR from the outside. Any help/hint would be appreciated. X13 short plan.zip Edited June 3, 2022 by CV-reno Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 3, 2022 Share Posted June 3, 2022 See if this helps. DJP Link to comment Share on other sites More sharing options...
CV-reno Posted June 4, 2022 Author Share Posted June 4, 2022 David, Thanks for taking the time to look into my issue. The rafter poking down into the bathroom: yes, I can ignore it by turning off roof rafters in camera view, but I'm concerned that there is still a problem with that particular rafter; as I said in my original message "rafter that isn't cut as the adjoining rafters are" Image 2 shows different colors for the wall in PBR: interesting that you don't have the same issue with X14, maybe a driver issue on my part? But my gut feeling, as I've seen this before, is that CA is struggling to generate that view because it gets confused by some aspect of that wall. My main issue though is the one depicted by images 3 and 4 (south wall of bedroom over the garage with a blue wall). Link to comment Share on other sites More sharing options...
Mark3D Posted June 4, 2022 Share Posted June 4, 2022 I opened your file in x14 rtrt and x13pbr and don't see wall color problem Link to comment Share on other sites More sharing options...
CharlesVolz Posted June 4, 2022 Share Posted June 4, 2022 Your edge rafter (in red) is 11 1/4" instead of 9 1/4" like the rest. Change that to match. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 5, 2022 Share Posted June 5, 2022 Change the ridge size to the same as rafter size and it will rebuild correctly. Ridges, ledgers and hips are the same when they should be different DBX's, t hen change the ridge after you turn off auto framing. Chief has been like that as long as I can remember. Link to comment Share on other sites More sharing options...
CV-reno Posted June 5, 2022 Author Share Posted June 5, 2022 @Charles @Perry, Thanks, one problem solved! Any hints for problem in images 3 & 4 ? Link to comment Share on other sites More sharing options...
Dermot Posted June 5, 2022 Share Posted June 5, 2022 CV-reno, there appears to be a problem with your product registration. Please contact our technical support department during our normal business hours for additional help in this matter. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted June 6, 2022 Share Posted June 6, 2022 On 6/5/2022 at 12:15 PM, CV-reno said: Any hints for problem in images 3 & 4 ? I thought David Potter helped with that is his video. Did you watch that? Link to comment Share on other sites More sharing options...
