Lower roof soffit cut off by overlapping upper roof overhang
snoopy1963
Go to solution Solved by rgardner,
Thank you all for your solutions to my dilemma and thanks to Ryan. I created a ceiling plane and railing wall without the drywall and it worked. Thanks Ryan. Here's my final presentation rendering on Lumion with a few quirks but looks ok. I exported the Chief Architect Collada model file into Lumion and it worked like a baby. I'm just blown away what I can create on Chief and how it seamlessly integrates with other software. Pretty awesome.
Expand
This shouldn't be needed it means the Room Ceiling Height is too low if using Auto Railings with post to beam , the Roof plane should be sitting right on the beam, with Rafters cut over beam, and thus Chief won't add the Auto - attic wall above
Lowering the roof Plane would do the same thing but is probably not the desired solution.
* PS - nice Job in Lumion.
