winterdd Posted February 13, 2022 Share Posted February 13, 2022 I have gotten used to making my caps like shown below for quite a while now. Is there a better way to achieve brick caps instead of having to uncheck "full wall width" and manipulate the number just to get the cap to overhang the brick stem wall? It works great but obviously isn't constructed like this in the real world. It is also shown wrong in cross sections. The cap should only be covering the brick part of the wall. Just trying to get better folks. Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 14, 2022 Share Posted February 14, 2022 2 hours ago, ChiefUserBigRob said: It is also shown wrong in cross sections. could think of a few methods.. Ca you provide a detail for how it should look in CS? Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 14, 2022 Share Posted February 14, 2022 Make 2 walls? One just for your 3” brick veneer which you could split into a pony wall showing your brick below and your siding above? Sounds scary but it does work. Just make sure your outer wall is “no room definition”. Link to comment Share on other sites More sharing options...
mtldesigns Posted February 14, 2022 Share Posted February 14, 2022 I use a molding on the top.. like a belly band, but a brick profile. Then I don't have to mess with any setting. Link to comment Share on other sites More sharing options...
winterdd Posted February 14, 2022 Author Share Posted February 14, 2022 57 minutes ago, mtldesigns said: I use a molding on the top.. like a belly band, but a brick profile. Then I don't have to mess with any setting. Yeah, I tried that before and it seemed more time consuming. But it does look great. Link to comment Share on other sites More sharing options...
winterdd Posted February 14, 2022 Author Share Posted February 14, 2022 2 hours ago, Renerabbitt said: could think of a few methods.. Ca you provide a detail for how it should look in CS? Here is a CAD detail I normally use for these type walls. Link to comment Share on other sites More sharing options...
winterdd Posted February 14, 2022 Author Share Posted February 14, 2022 1 hour ago, Michael_Gia said: Make 2 walls? One just for your 3” brick veneer which you could split into a pony wall showing your brick below and your siding above? Sounds scary but it does work. Just make sure your outer wall is “no room definition”. I hear ya, the bricked part is a fdn wall and the siding is an exterior wall already. Thanks. Just figured I was doing things the hard way but maybe there isn't a correct one way to achieve this. Link to comment Share on other sites More sharing options...
SNestor Posted February 14, 2022 Share Posted February 14, 2022 @ChiefUserBigRob - just an idea...would not say it's ideal but here you go. I used a pony wall for the frame wall...just a short 3" tall section of 8" CMU and a wider brick sill. The wider is just to make it appear to be a sill. I created a new material for the sill (made a copy of the dark brown brick material), changed it's orientation etc. It's not a perfect solution. Using a molding polyline would be faster, easier...but there are always a number of ways to do things in Chief. 1 Link to comment Share on other sites More sharing options...
glennw Posted February 15, 2022 Share Posted February 15, 2022 If you can use a pony wall to configure your walls properly, Chief will place the auto Wall Cap from the outside of the upper wall layers. This may not fit your situation though. Link to comment Share on other sites More sharing options...
