Bill_Emery Posted March 11, 2014 Share Posted March 11, 2014 I'm looking to change the defaults for the layout box labels, and I've not been able to find them. Can someone point me in the right direction. Link to comment Share on other sites More sharing options...
GerryT Posted March 11, 2014 Share Posted March 11, 2014 Not sure what you mean by a "Label Default" Never heard of that. Are you trying to change the view title?? Need more info? Link to comment Share on other sites More sharing options...
dshall Posted March 11, 2014 Share Posted March 11, 2014 I'm looking to change the defaults for the layout box labels, and I've not been able to find them. Can someone point me in the right direction. If you want to control the text that is done via the layout box label layer. Link to comment Share on other sites More sharing options...
Bill_Emery Posted March 11, 2014 Author Share Posted March 11, 2014 Hi Gerry, Thanks for the reply. Specifically, I'm trlying to change the default for the label offset for the layout boxes. I know it's something simple, but just can't find it. Link to comment Share on other sites More sharing options...
GerryT Posted March 11, 2014 Share Posted March 11, 2014 I believe that's hard coded, but might be buried somewhere in their INI file. I could not find anything but I'm sure Tech Support could find it for you? Link to comment Share on other sites More sharing options...
Bill_Emery Posted March 11, 2014 Author Share Posted March 11, 2014 I do like those labels, but it's a little annoying to have to change the offset on each one. Gerry, and Scott: Thank you for the help Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 11, 2014 Share Posted March 11, 2014 after sending to layout just drag it to wherever you want, it stays unless you have to send another view for some reason. Link to comment Share on other sites More sharing options...
Bill_Emery Posted March 11, 2014 Author Share Posted March 11, 2014 Thanks Perry, I never thought of dragging them! Link to comment Share on other sites More sharing options...
CJSpud Posted March 12, 2014 Share Posted March 12, 2014 The drag handle for the label is pretty small in my opinion. I would like to see it bigger so you can easily grab it without having to zoom in to find it. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 12, 2014 Share Posted March 12, 2014 The drag handle for the label is pretty small in my opinion. I would like to see it bigger so you can easily grab it without having to zoom in to find it. Yes ,you have to zoom in to see it sometimes, to me it just another click that is not needed. Link to comment Share on other sites More sharing options...
mgabriel Posted March 12, 2014 Share Posted March 12, 2014 aren't the handle settings adjustable in the preferences, somewhere with the selection color and such??? For some reason I am thinking you can assign a pixel count for selection handles to control size. I will look into that... Link to comment Share on other sites More sharing options...
dshall Posted March 13, 2014 Share Posted March 13, 2014 aren't the handle settings adjustable in the preferences, somewhere with the selection color and such??? For some reason I am thinking you can assign a pixel count for selection handles to control size. I will look into that... I am sure you are correct Mike, I don't mess with it because then the handles would be TOO BIG. I just zoom in, I suppose it could be made more user friendly. Link to comment Share on other sites More sharing options...
Doug_Park Posted March 13, 2014 Share Posted March 13, 2014 The handle sizes are settable in preferences. The handle doesn't change size when you zoom. If the issue is that you are having trouble seeing it then changing the colors would probably be the better solution. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 13, 2014 Share Posted March 13, 2014 Sometimes the label hides the handle and you can't see it. until you zoom very close to it, no matter what size it is. Link to comment Share on other sites More sharing options...
dshall Posted March 13, 2014 Share Posted March 13, 2014 The handle sizes are settable in preferences. The handle doesn't change size when you zoom. If the issue is that you are having trouble seeing it then changing the colors would probably be the better solution. Thanks Doug, never messed with it before, OOB is 4, no complaints on the OOB, I just bumped it up to 6 to see if I like it better. Does any body know what the BUMPING/PUSHING FOR TYPE I MOVEMENT is about? I just noticed this, I believe this is new, anybody know? Link to comment Share on other sites More sharing options...
Doug_Park Posted March 13, 2014 Share Posted March 13, 2014 That addresses one of your requests from beta to not use bumping or pushing when you use tab/enter or type in dimensions. Unchecking it puts things back to the way they were in X5 where moving things using dimension or tab/enter would also push or bump. This does mean you can push cabinets into walls, but so far no one has complained about the change in behavior so I think we got the out of box setting right. Link to comment Share on other sites More sharing options...
dshall Posted March 13, 2014 Share Posted March 13, 2014 That addresses one of your requests from beta to not use bumping or pushing when you use tab/enter or type in dimensions. Unchecking it puts things back to the way they were in X5 where moving things using dimension or tab/enter would also push or bump. This does mean you can push cabinets into walls, but so far no one has complained about the change in behavior so I think we got the out of box setting right. Hmmmm, I assume the OOB setting is unchecked, if that is the case..... yeah..... now that you mention this, I have not noticed this frustration, thanks. If you ask me, it should always be unchecked, not sure why anybody would want this checked, I will monitor now that I know this. Link to comment Share on other sites More sharing options...
Doug_Park Posted March 14, 2014 Share Posted March 14, 2014 I don't either, but I had significant push back from several sources that prompted me to make this a preference. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted March 15, 2014 Share Posted March 15, 2014 What's OOB? Link to comment Share on other sites More sharing options...
dshall Posted March 15, 2014 Share Posted March 15, 2014 What's OOB? oob= out of the box settings. Open CA, open new plan, that plan is oob, (CA's default settings). 1 Link to comment Share on other sites More sharing options...
Adam_Gibson Posted March 15, 2014 Share Posted March 15, 2014 Ahh, Thanks. Link to comment Share on other sites More sharing options...
glennw Posted March 15, 2014 Share Posted March 15, 2014 OOB more commonly means the settings that are shipped with a fresh install of the program (these are usually called factory defaults) which may not be the same as New Plan. A New Plan opens your default template plan - not the OOB settings. If you go to Preferences...Reset Options, you can set preferences back to the factory defaults or OOB settings. Link to comment Share on other sites More sharing options...
