More Stair Problems
Doug_N
55 minutes ago, Doug_N said:
Here is the plan file
I think you may also need to offer a reward.
It seems you need not just a wall but room definition as well but then you also get other surprises as one might expect. ;)
Firstly, I think you need to clean up the geometry and get things accurate.
Your cad guide, walls and stairs don't appear to be snapped to each other correctly.
The joining of the stairs to other stairs is controlled by the Allow Rap setting.
The extension of the stairs at each side is controlled by the Winders setting.
But...to get the winders setting to work, the stairs have to be in a room.
So you need to create an invisible room.
But....I can get the winders to build on one side, but not both.
That helps but as soon as I create a room I loose the Rap but can achieve two Winders for some reason.
Too bad you can't edit stair treads like decking boards.  That would solve the problem pretty quick.
