BillsburgChief Posted October 8, 2021 Share Posted October 8, 2021 I'm not sure why my windows won't show up plan view. I can click on the openings and they show up in the dialogue box and also in camera views, so I know they are in there, just can't see them. 1502294526_21-012CrownResidence.plan Link to comment Share on other sites More sharing options...
rlackore Posted October 8, 2021 Share Posted October 8, 2021 I see your windows when I open the plan: Link to comment Share on other sites More sharing options...
BillsburgChief Posted October 8, 2021 Author Share Posted October 8, 2021 Yeah Robert, I'm not sure what is going on. If I open my plan or the one I attached they don't show up. Link to comment Share on other sites More sharing options...
robdyck Posted October 8, 2021 Share Posted October 8, 2021 Can't help you with the window display, but did you know you can use a truss for ... the truss? It looks a lot better in 3d! Link to comment Share on other sites More sharing options...
BillsburgChief Posted October 8, 2021 Author Share Posted October 8, 2021 I can see them in the referenced floors and they will print, just won't show up in the plan Link to comment Share on other sites More sharing options...
rgardner Posted October 8, 2021 Share Posted October 8, 2021 6 minutes ago, BillsburgChief said: I can see them in the referenced floors and they will print, just won't show up in the plan Looks like your foundation walls layer is turned off. Link to comment Share on other sites More sharing options...
joey_martin Posted October 8, 2021 Share Posted October 8, 2021 Check the distance between the W/C and the counter top corner. Link to comment Share on other sites More sharing options...
BillsburgChief Posted October 8, 2021 Author Share Posted October 8, 2021 Ryan - The foundation walls layer is turned on (my CMU fill was not), but it is happening on all the floors, 1st floor and attic level Link to comment Share on other sites More sharing options...
Solution Dermot Posted October 8, 2021 Solution Share Posted October 8, 2021 Is the color of your windows the same as your background color? Try changing one of them to see if they are more visible. Link to comment Share on other sites More sharing options...
BillsburgChief Posted October 8, 2021 Author Share Posted October 8, 2021 I just noticed the same thing is happening w/ my door casing trim, door shows fine, but no casing in plan view only, shows up in all other views and prints fine same as the windows Link to comment Share on other sites More sharing options...
BillsburgChief Posted October 8, 2021 Author Share Posted October 8, 2021 9 minutes ago, Dermot said: Is the color of your windows the same as your background color? Try changing one of them to see if they are more visible. Dang... I knew it had to be a setting somewhere, didn't even notice that. Thanks Dermot! Link to comment Share on other sites More sharing options...
robdyck Posted October 8, 2021 Share Posted October 8, 2021 I see that background colors don't stick with an attached file as they are controlled by the program preferences. I noticed right away that the windows were grey and was wondering if you're background color was too dark. Link to comment Share on other sites More sharing options...
BillsburgChief Posted October 8, 2021 Author Share Posted October 8, 2021 3 minutes ago, robdyck said: I see that background colors don't stick with an attached file as they are controlled by the program preferences. I noticed right away that the windows were grey and was wondering if you're background color was too dark. Yeah, I've been playing around w/ the background w/ the new version, so I actually had quite a few layers I had to change. Now I know! Link to comment Share on other sites More sharing options...
robdyck Posted October 8, 2021 Share Posted October 8, 2021 2 minutes ago, BillsburgChief said: Yeah, I've been playing around w/ the background w/ the new version, so I actually had quite a few layers I had to change. Now I know! Yup been there! And once you're down that hole, it can be tough to get out! Link to comment Share on other sites More sharing options...
Chelanman Posted May 15, 2022 Share Posted May 15, 2022 I had this issue too, sort of. I had a door and a window in the same wall. The door was visible in the plan view but the window was not. I managed to fix it by deleting the foundation wall underneath it and then putting it back in. The weird thing is there were no breaks in the wall itself the foundation wall underneath it. I love Chief but it can drive you nuts sometimes. Link to comment Share on other sites More sharing options...
