Macro not working properly with leader.
I use a simple macro for commercial as-builts to describe room info for clients  (the ceiling height macro is from Joe):
%room.name%
%room.dimensions%
%room.ceiling.finish.name% @ %ceiling_Height_Label%±
%room.floor.finish.name% FLOORING
Since I started using X13, if the label does not fit, I use a leader line, it appears to gather the ceiling height info from the room the block is in rather than where it is pointing to.  I have been doing it this way for years.  The ceiling height is supposed to be 9', but it is getting its data from the room the block is in.
Hoping someone has a solution...
%room.name%
%room.dimensions%
How are you "snapping" the leader-line to the Room?
Does the Block need   UN-Blocking to work?
2 minutes ago, solver said:
Have you asked Joe?
Not yet...
X13 changed this behaviour so that is my first guess at the issue and will ask Joe if this does not provide me an answer to solve the issue.
Are you by any chance getting an  #Evaluation Error#  where you are expecting the formatted ceiling height ?
On 7/18/2021 at 9:16 PM, Dermot said:
As far as I can tell, the built in macros work just fine.  Probably best to talk with Joe about this.
Ugghhh.   I put up this post and did NOT add the image to show what it is doing.
The "room label" I created works when placed in the room.  When it is not in the room, it uses the ceiling height value from the room I have it located in.  I will ask Joe...
AFAIK, the macros need to be a Referenced Object for arrows to work, not an Owner Object
20 minutes ago, Alaskan_Son said:
Are you sure the arrow is actually connected to your text box?
It is...
6 minutes ago, Alaskan_Son said:
Is it a text box or a CAD Block?  If its a CAD Block, unblock it.
Not a cad block...
5 minutes ago, wjmdes said:
Not a cad block...
Okay.  Your statement was just a little confusing....
Are you sure your arrow is set to Attach to Other Objects?
By the way, there are other things you can do as well such as connecting the leader to another object IN that room but it should actually work without doing that.  If I simply copy and paste the text from your original post into one of my plans and then connect that text box to a room with an arrow, I get the information for the neighboring room, not the room that the text box is sitting in.  Dermot showed the same thing in his example.
There is another confusing statement.....   Maybe you have a magic copy and paste ?
Bill's posted example also pulls the data from the neighboring room.  The problem is Joe's %ceiling_Height_Label% macro does not work the way the global macro's do.  I did not see a copy of Joe's macro posted.
Oh, I see.  I must have misread the first time around.  I didn’t realize that it was only Joe’s macro.  That would obviously depend on how the macro was written.  I would try connecting it to another object in the neighboring room through.  Another blank text box might even do the trick.
I posted a plan before for help and it had Joes macro in it and I was politely asked not to post his macros he sells by a third party.....
BTW, it was clear to me when I wrote it :)
Sorry I was not requesting that...   I know the rules.   It just seemed that Michael had a copy based on his comments that he later retracted.
    29809
    WHDesigns
    WHDesigns
