dnpayne Posted December 11, 2014 Share Posted December 11, 2014 I'm ready to start getting the construction documents (standard blueprint layouts) setup for my plan. Whats the most efficient way to go about this? I'd like to get the position the same from page to page. Do I create a template?Any help would be great. I haven't messed with generating these as of yet. Link to comment Share on other sites More sharing options...
johnny Posted December 11, 2014 Share Posted December 11, 2014 Check this site out for great videos on how to do this... http://www.chieftutor.com/ More specifically check this out... http://www.chieftutor.com/scotthall/ Link to comment Share on other sites More sharing options...
JJohnson Posted December 11, 2014 Share Posted December 11, 2014 I'm ready to start getting the construction documents (standard blueprint layouts) setup for my plan. Whats the most efficient way to go about this? I'd like to get the position the same from page to page. Do I create a template? Any help would be great. I haven't messed with generating these as of yet. Because everything on layout page 0 will show on the rest of the pages (which is why your title block, project name etc are there), you can place temporary markers that will show on the rest of the pages, (like a red arrow to show where to drag the upper left corner of floor foundation etc plans). Then all your plans will be at the exact same place on their pages. You only need to delete them (the temp markers) when layout is ready. Link to comment Share on other sites More sharing options...
lbuttery Posted December 11, 2014 Share Posted December 11, 2014 You only need to delete them when layout is ready or place on a layer(in layout) to turn off when not needed then if you use the "save as method" as advocated by Scott they will be there ready for the next project Lew Link to comment Share on other sites More sharing options...
HumbleChief Posted December 11, 2014 Share Posted December 11, 2014 In X6 each Layout box has an Annotation Set associated with it. If you want to locate boxes in the same location on each page you can copy and paste/hold position each layout box from page to page then change the associated Anno Set for each box. Select the Layout box and 'Open Object' (not double click) and you'll see the Anno Set(s) (and reference sets) you can associate with that box. Link to comment Share on other sites More sharing options...
mgabriel Posted December 12, 2014 Share Posted December 12, 2014 I'm with Larry on this one. Copy...paste-hold position...change layer set-anno set associations But to each there own. There's a hundred ways to skin this cat. Link to comment Share on other sites More sharing options...
dnpayne Posted December 15, 2014 Author Share Posted December 15, 2014 Thanks all for the replies. I'm going to dig into this hopefully this week. Link to comment Share on other sites More sharing options...
LevisL Posted December 15, 2014 Share Posted December 15, 2014 In addition to what Larry and Mike have mentioned, that method allows you to change floors as well, not just annosets. Makes it real easy to have the foundation, main floor and second floor (or whatever levels you have) all line up from page to page. Link to comment Share on other sites More sharing options...
