skoz44 Posted March 4, 2021 Share Posted March 4, 2021 I have a 15’ x 15’ conference room that I’d like to setup with a large TV I can display CA. The purpose is to use some rendering samples to WOW an initial prospect and to have existing clients come to my office for design reviews (no rendering, just floor plans). And of course for large Zoom meetings as well. I imagine the system would only be used for these events and not for normal drafting. Can anybody recommend a micro computer or suggested specs for one? Due to the limited use, Im not sure if the high ram and video card are needed. Any suggestions for other equipment and TV size would also be appreciated. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 4, 2021 Share Posted March 4, 2021 1 hour ago, skoz44 said: I have a 15’ x 15’ conference room that I’d like to setup with a large TV I can display CA. The purpose is to use some rendering samples to WOW an initial prospect and to have existing clients come to my office for design reviews (no rendering, just floor plans). And of course for large Zoom meetings as well. I imagine the system would only be used for these events and not for normal drafting. Can anybody recommend a micro computer or suggested specs for one? Due to the limited use, Im not sure if the high ram and video card are needed. Any suggestions for other equipment and TV size would also be appreciated. Just about any computer should work for this, connected via HDMI. The output is pretty grainy, like monitor resolution blown up, but you're usually sitting some distance from the TV so it's not bad I do this in client's homes sometimes, using a basic HP laptop and a long HDMI cable, so long as they have a TV with an HDMI port and know how to change the input And even with the basic CPU graphics of the laptop, I can do 3D views and navigate quickly and easily Link to comment Share on other sites More sharing options...
MarkMc Posted March 4, 2021 Share Posted March 4, 2021 If its a smart tv OR you use a Roku stick the laptop in you signature will work. Windows key + p will bring up the project dialog. Both need to be on same network and set tv to computer. I did this all the time with a 42" tv in the studio. Link to comment Share on other sites More sharing options...
skoz44 Posted March 4, 2021 Author Share Posted March 4, 2021 Well that's good to know. So you guys don't run into delays or slow movement when you show the project in 3D? I assumed I was going to have to have something with high RAM like my desktop. Link to comment Share on other sites More sharing options...
MarkMc Posted March 4, 2021 Share Posted March 4, 2021 GPU and CPU matter more than ram. If Chief runs ok on laptop should be ok on tv though higher resolution will tax GPU. Easy enough to test and in house wireless is the way to go lMO. If your desktop has wireless you canproject that to TV even from another room. Link to comment Share on other sites More sharing options...
lbuttery Posted March 4, 2021 Share Posted March 4, 2021 in 2008 I was thinking of using multiple monitors instead I went with 38" tv and used it for daily working with Chief and for client presentations I had to sit about 8" back or I would fry my eyeballs it worked great for using Chief and when clients came - no more hovering over small PC screen I was using VGA connection as PC didn't have HDMI it looked fine HDMI is even better I imagine a 4K tv would look great Lew Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 5, 2021 Share Posted March 5, 2021 1 hour ago, lbuttery said: I imagine a 4K tv would look great Yep ! See my signature. Link to comment Share on other sites More sharing options...
Electromen Posted March 6, 2021 Share Posted March 6, 2021 Is there anything similar to Apple's Air Play? I use it with a Sony 65" TV and my Mac desktop and laptop. It's a wireless connection that works very well without delays and is 4K Link to comment Share on other sites More sharing options...
MarkMc Posted March 6, 2021 Share Posted March 6, 2021 57 minutes ago, Electromen said: Is there anything similar to Apple's Air Play? I Already noted above Link to comment Share on other sites More sharing options...
