Make X12 the Default Program (Windows 10)
joeyaccount
When I click on a file in a folder (Created w/ X12) Chief attempts to open.  A dropdown box appears and ask for Serial #.  I put in my serial number and a message appears not valid.  How to make X12 the default program such that when I click on a file created in X12, X12 will open displaying the file and ready to work?
Joey B
Joey B
Expand
Sounds like you might have an issue.  I would recommend calling chief on monday with your key number handy so they can help you resolve your issue. @Dermot
since I have always had multiple versions of Chief installed
I select the plan to be opened via Windows explorer via right click and then select "open with" and choose which version of Chief to use for that plan
in that dialog there is a setting to "always use..." for the .plan extension
use this if you only want X12 to open .plan files
Lew
